Results 1 to 10 of 17
Thread: 300TDi Timing Belt
    300TDi Timing Belt
    Once the timing belt on the 300 Tdi has been replaced, does it still need doing every 80,000km, or does the retro-fit fix the issue.
    A friend's looking at getting a Defender that had the belt done 85,000km ago and it's 1,200km away. How soon should he do the belt? Should he risk the drive back?
    Thanks, Michael2
    Mar 2007
    Bulimba
    The short answer is yes. All timing belts have a life span and seeing as the cost of mechanical carnage (and inconvenience) its cheap insurance. If I bought a car with a unknown history I'd renew the belt for peace of mind
    Quote Originally Posted by petemci View Post
    Agreed!
    In my case it was easy. The belt had been replaced 59,500 km before I bought it so I replaced it after purchase. I also did the pulleys, etc.
    Unfortunately, the previous mechanic had centre-popped the crankshaft nose (to expand it) and then loctited the belt pulley and the harmonic balancer on. They needed oxy to get them off.
    Ron
    Tregeagle, NSW
    I agree keep up a regular cycle and things will be good.
    Hey Ron, I must have had a touch of the 'Rons' when i had my timing belt done, lucky i opted for a preferred supplier, it took them ages to get the timing belt pullery off, why, some genius had loctited it on, well no genius, the previous one had been done by a 'dealer'.
    john
    Lesmurdie - Perth WA
    You might find it's a requirement to loctite the pulley on. My manual ( for 200TDI ) requires the harmonic balancer and bolt to be loctited
    Melbourne, outer South East
    That's true, they didn't loctite properly when they did my timing belt and it caused the timing to go out and seriously affect performance.( lots of white smoke and no power )
    Quote Originally Posted by Graz View Post
    On the 300Tdi, the manual doesn't specify either - in fact it says to grease the crankshaft!
    Refit
    12. Refit in reverse order, lightly greasing pulley
    spigot. Tighten to 80 Nm + 90°.
    Ron
    Safety Bay
    Micheal2 I would replace the lot on a vehicle I didn't know about.I have changed my belt every 80k and the timing gears every second belt.I had a pulley break on my engine and bent two pushrods and a rocker so for peace of mind I'd do the lot. Pat
    Thanks for the replies. It looks like he'll have to get the Defender trucked down and get the timing belt done immediately if he wants to buy it.
    Safety Bay
    One more thing,some places charge like a wounded bull so get a quote first.Changing just the belt should cost no more than $300. Pat
