Thread: Ubuntu Linux - upgrading systems...?
    Melbourne, Vic
    I know how to upgrade a hard drive on a system, but how about upgrading the system around a hard drive....?
    I'm running the most recent release of Ubuntu, headless, and using it as a torrentbox and network drive (LAMP server).
    The current PC (Compaq, P3 1Ghz) is in a big case, that I want to down-size into a smaller case, to take up less room, make less noise etc... The smaller case one I have currently contains a Abit, P4 1.6Ghz.
    Is it a relatively "simple" matter of swapping the HDD or is there more to it? or do I need to rebuild it?
    Current: ‘16 Disco Sport (7seater) aka « Family Bus 2 »
    Sadly Gone: '77 RRC 2 Door aka "Beast"
    Gone: '92 RRC Vogue SE aka "The Family Bus"
    Long Gone: '99 Td5 Defender aka "The TANK!"
    St Helena,Melbourne
    4.28 MB
    Your current hhd wont have the drivers on it to recognise the new mb, usually have to re install the os after the upgrade. There may be a way to update the mbr (master boot record or whatever Ubuntu calls it) , i know it can be done on a win pc but not sure about linux.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Gold Coast, QLD
    I think ubuntu may work, if i am right you are taking your ubuntu equiped HDD and putting it in a different machine.
    I used ubuntu for abit but never really liked it (xp was and still is quicker for me) I'd say give it a go and use it as a learning curve
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you try the automated update install that comes with your distribution
    or
    you may have to build a kernel that suits the hardware in your new machine to get it to boot.
    if they are both the same hard drive controllers you stand a good chance of having it easy....
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Melbourne, outer South East
    maybe try asking on here
    http://bleedingedge.com.au/blog/
