Results 1 to 10 of 17
Thread: My SWB Series1 ID
    Roverray Guest
    Lightbulb My SWB Series1 ID
    Number from Rover car id on firewall under bonet
    R06113288
    Engine N0. 06113727
    Any info appreciated?
    Roverray Guest
    I bought it in about 1975 from a property at Peak Downs near Capella Qld. They said it had been parked in the house padock for many many years. Solid towed it back to an exploration camp I managed. Cleaned the points and plugs Gravity fed some petrol to the carby - old elect pump not to good- put battery in - started - went for a drive. no brakes etc but hand brake worked.
    1976 moved work location so put on back of FJ75 cruiser and moved it home for storage and later rebuild. Hung in shed for 30 years - yes that is HUNG - recently moved it to Rocky Property Chassis is bad it but have another that may be ok.
    It is in original bush repair condition which I think I should write up before rebuild as it is interesting to say the least.
    When I get a digital camera going I will fully document it.
    It is possible it may have been associated with the British Food Corporation that set up out there after WW2 and later went bust.
    Roverray Guest
    Another question?
    so would the original motor eng no match the vehicle No.?
    Roverray Guest
    Unfortunately I do not have a drivers door. but I do have a set of later s1 doors possibly 107 as they are grey and straight backs
    Quote Originally Posted by Roverray View Post
    86,88,107 and 109 Series 1 doors are identical (and different from 80" doors, of which there were at least two types). But the Grey paint (if original) does strongly suggest a 107 or 109.
    Roverray Guest
    107 I reckon - it swings on the hinge mounts on the 80.
    I think I know where I can get a door, fingers crossed!
    The significant difference in 80" doors came with the 2 litre engine in 1951, and was the introduction of an outside door handle in place of the canvas triangle in the door top. Given a pattern to work from, it should be relatively easy for any engineering shop to make a copy. Except for the handles, I think the lock is the same as later Series door locks.
    Roverray Guest
    Quote Originally Posted by Numpty's Missus View Post
    We recently visited a bloke in Toowoomba who is slowly restoring a 1951 S1......he had a door skin that a mate had made for him ( I think it was sheet aluminium he'd used). It looked pretty good.
    I think I might be able to pick up a door from a friend remember seein it laying in a padock.
    Nundle
    Further to this though not 80 related. 86 and 88 rear tub are interchangeable, but the front guards are different (longer on 88) 86 front guards should fit 107, and 88 front guards fit 109.
    Numpty
    REMLR No 143
    Sunny Pucka
    Wasent the front end made longer to fit the desiol donk from 56-57 onwards?
    Easo
