Results 1 to 9 of 9
Thread: Split rims.
    Sunny Pucka
    Split rims.
    The old girl has splitties, but my question is what does the plate this mean?
    It's on the out side, theres another on the inside that says ensure tyer id deflated before seperating. For those who haven't seen the splits before,
    Cheers Easo
    Toowoomba, Queensland
    Dunno what the W.D. is. 5.50 = 5 1/2 inches wide E pattern retaining bead. FV84930 = part number (reportedly the FV designation means military part number though frequently used on parts also available on civilian machines)
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1963 Series IIa Ambulance
    1977 Series III Ex-Army
    1988 County V8
    1981 V8 Series 3 "Stage 1"
    REMLR No. 215
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by scrambler View Post
    FV = Fighting Vehicle
    Are the 5.5" detachable rims the ones for the Land Rover or the ones for the Austin Champ?
    There should also be the Rover part number (217267) somewhere on them.
    Split rims are something I am still getting my grips on.
    Diana
    Quote Originally Posted by Numpty's Missus View Post
    Split rims I understand are designed to make tyre changes easier, hence their military use.
    Does this mean then that once the 8 nuts are undone the rim comes easily away from the tyre, as the bead is easier to break? and does it always work that easily?
    It means that the near 1/2 of the rim comes away, and the other 1/2 remains attached. Of course only works with inner tubes Means there is no bead to break at all, just lift 1/2 rim and remove tyre carcass and tube, replace tube and/or tyre, re-attach bolts and continue.
    Steve
    2003 Discovery 2a
    In better care:
    1992 Defender
    1988 County V8
    REMLR No. 215
    That is the idea, but in practice, you still have to break the bead, and how hard that is depends mainly on how long its been there and how rusty it is.
    I have seen a split wheel in 1969 (not on a Landrover but on a Blitz) that had not been apart since 1945, despite living in North Qld all that time. After several days hard work the owner gave up and removed the tyre with an oxy torch.
    The advantage is that you do not have to get the bead of the tyre into the well, which can be a real advantage with very heavily built tyres. But this minimal advantage, plus the additional cost and the fact that the nuts are often rusted solid when you want to change the tyre, are probably why these wheels have always been so rare. I am not sure when they stopped being available, but I think they stopped listing them as an option with the series 2a, although I suspect even today you could get them if you had a bulk order!
    1.20 MB
    Pat
    It does work that simply, the rim is in 2 halves, the front side of the rim comes away from the rear part that is attached to the center disk.
    Just be very careful to deflate the tyre and remove the valve first before undoing the bolts, lest the rim comes apart explosively.
    BTW do others know that the front part of the rim and all the bolts etc are exactly the same as the WWII Jeep split rim. So if you have a rusty front bit etc you can get reproductions from the US Jeep suppliers. Unfortunately not for the Land Rover pattern part however.
    Diana
    Exclamation
    Pat
    BTW do others know that the front part of the rim and all the bolts etc are exactly the same as the WWWII Jeep split rim. So if you have a rusty front bit etc you can get reproductions from the US Jeep suppliers. Unfortunately not for the Land Rover pattern part however.
    Diana
    Interesting - I didn't know that. I would be (slightly) surprised if the thread on the bolts were the same - it would be most surprising if the Landrover ones were not BSF, and equally surprising if the Jeep ones were not NF (or possibly UNF). Although if they are actually the same I'd guess that the Landrover ones are NF, and the Landrover split rims actually used Jeep components!
    Sunny Pucka
    1. Firstly you gotta deflate the tyer.
    2. Either use a bead braker or the front drivers tyer to losen the bead.
    3. undo nuts and seperate rim.
    4. Fix the busted bit reassemble in reverse order, ensuring you dont pinch the tube between the rims.
    When I get a chance I've gotta take them all apart to give them a clean so I'll post pics.
    Easo
    Cessnock NSW
    G'day All, FV = Fighting Vehicle, W.D = War Dept, and apologies if someone had posted that info, my eyes are hanging out of my head so 2 speak, too many nite shifts and not near enough sleep cheers Dennis
