Originally Posted by
googe
1. hey all,can anyone tell me if the guardes are series 2a or series 3?
2. also it has a single whiper motor,is that standard series 2?,it has a brake servo is that standard? im new to owning a landie lol as u can tell
, this one i just brought has holden motor,5 speed,gas,rear bench seat facing forward,31.5x15,its all mod plated,so im a bit confused as to what the heck it is lol,any help would be great thanks,
Greg
1. It is difficult to tell externally late 2a guards from Series 3, although most Series 3 guards have a heater opening in the LH side. However, if you look under the guard, the 2a has a flat panel between the foot well and the top of the guard, whereas the Series 3 has the flange further forward and a formed panel to allow for a dual, power assisted master cylinder. It is possible that this panel is missing, but the attachment for it on the guard should be there, and you can see if it lines up with the floor slope.
2. The detail is not quite good enough to see in the picture, but Series 2 and Series 2a up to 1967 had a separate wiper motor for each side, with the LH one being optional (although required by some states by 1967), mounted on the windscreen frame itself. After 1967 a wiper motor was mounted in the LH end of the parcel tray and drove two wipers by cables, with the wheel boxes attached to the very top of the bulkhead above the ventilators rather than to the windscreen itself.
The guards with headlights were fitted from 1968 (suffix G) and this example is either an earlier one fitted with later (or S3 guards) or a suffix G fitted with the earlier radiator support panel.
The key to the original state of the vehicle is the chassis number, or more particularly, the letter suffix to it. Perhaps the major changes were at suffix D when the electrical system was changed from positive to negative earth, along with a lot of other changes to the electrical system (e.g. key start, temp gauge, dual wipers as standard etc), and the G suffix (see above plus beefed up transfer case and gearbox). Since most bits are interchangeable, at least as complete assemblies, there is a good chance that the one you have is a bit of a mixture anyway. The chassis number should be on the plate in front of the gear lever, and also on the side facing flat of the LH rear back spring hanger.
