Results 1 to 3 of 3
Thread: Series 1 Spark Plugs
    Nundle
    Where oh where can you find info on spark plugs. Every motor manual I've ever had has listed the plug number and plug gap. Except for my Series 1 manual. All it mentions are.............it has spark plugs.
    Now, clever me already realised this, but not enough info. Who knows what spark plugs should a Series 1 2L spread bore motor use, and what would be the gap for same.
    I have received conflicting advice prior to this request and the plugs that were in the vehicle were not what was recommended to me.
    Numpty
    REMLR No 143
    master chief Guest
    Hello Numpty,i,m having a mental blank on the plug number [not unusual after a few ports].but the gap should be .029 to .032 thou.
    Oct 2003
    Godwin Beach Qld
    G'day Numpty
    I gave NM the info a few days ago, as we were having a discussion about the starter in Leon, the Rover part No is R262796 in my old plug cattle dog it states N8 Champion, but I prefer to use NGK B6es in 7:1 motors, I think that the oil might be the problem, as I had similar a few years ago, couldn't keep it in the motor, loosing it from the oil seals, and gummed up the starter and plugs, changed to Pentire 20w-40w and problem solved, oil stayed in the block, was loosing viscousity at temperature, starter clean, no fouled plugs, It may be worth a try, but that is only my opinion.
