with a stop watch![]()
inspired by a comment made in another thread about how long is a piece of string...
the objective is to time 15 minutes using 2 pieces of string that burn for one hour each... Heres the conditions..
you have only 2 wind proof matches, each match can only be struck once and will only stay lit for 10 seconds (perfect matches, they will strike on the first go, catch and stay lit)
you only have the 2 pieces of string.
the 2 pieces of string, other than the characteristic that they will both burn from one end to the other in exaclty one hour are in no other way similar. They do not burn in a linier rate, a given part of the string could burn for 10 seconds or 10 minutes and you have no way of knowing what part will burn for how long.
so given all of that,
how do you time 15 minutes?
EVL '96 Defender 110 - Emerald '63 2a Ambulance 112-221 - Christine '93 Rangy - Van '98 Rangy - Rachael '76 S3 GS - Special '70 S2a GS - Miss B '86 Rangy - RAAF Tactical 200184 & 200168
Cut them up to four pieces each, clever matches to light all eight pieces, and take and average ... or use a stop watch (as previously cited) or even a wrist watch .. close enough![]()
That was my initial thought too - cut them into quarters then take an average. For that, you need some way to measure burn times, and obviously you don't have anything to do so. Also, the second piece of string would be redundant.
We know burning a piece of string from one end burns for an hour, so burning it from both would halve it, regardless of its nonlinearity.
If we light string 1 at both ends and string 2 at one end, string 1 is burnt completely in half an hour. String 2 would still have 30 minutes left, so at that point we light its other end to halve the remaining burn time.
Our 15 minutes is from when string 2's other end is lit, until it's completely burnt.
Why not make a circle out of the hour long rope?
Start burning and use the position of the burn to estimate the time fairly accurately, like a clock.
Ben I realised my mistake and deleted the post.
However
I fail to see how a complete burn takes exactly one hour, yet cannot be linear
surely if the burn rate is accelerated then the complete burn time will be reduced.
Therefore the burn rate must be of a uniform acceleration to last exactly 1hr.
taking this to account
the burn can be uniform or controlled over a prescribed length.
for ease of brain at this hour in the morn prescribed length = 60cm
60cm = 1 hr to burn therefore 15cm = 15mins
C'mon man, it's 3:30 AM... in the morning... it's magic string ok. It just is.
Make a sundial out of rope 1.
Mark the position of the shadow
Use rope 2 as fuel (burns for exactly 1 hr in it's magic non linear way)
Mark the position of the shadow as 1hr after initial burn
Divide the angles by 4 and achieve 15 minute intervals.
I presume splicing the rope would not effect the burn rate of this magic rope?
