Results 1 to 10 of 22
Thread: Flashing LED Trailer Lights
    Hi All,
    I recently had some repairs done on my 6x4 trailer, and in my wisdom decided to fit some LED tail lights. Whilst they work fine when I tow it with my Valiant ute, once it's behind the D3, the indicators pulse continuously (ie. on a dull day, it looks like I have my hazard lights on).
    The "expert" at the trailer place suggested that is was the electronics sending a signal to the trailer plug to determine if a trailer was connected. Given that LED's require only a tiny amount of current to light up, every pulse causes the lights to flash. Also, the trailer light on the dash no longer flashes as it used to when the original globe lights were fitted.
    Has anyone else come across this, and if so, is there a simple solution (other than ditching the LED lights)?
    Thanks,
    Jeff
    Nedlands, WA
    You need a pulse shunt device.
    try here www.labtronx.com.au
    or email here led.module@gmail.com
    Common problem.
    Lee Bourgeois has developed a fix for Land Rover.
    See http://www.labtronx.com.au/
    Thanks gents.....pulse shunt it is (although binning the LED lights might be cheaper)!
    Jeff
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by heycharger View Post
    Cheers, Jeff
    Jeff
    If you want the trailer light on the dash to work you need more load on the trailer. The easiest way is to leave the LED's there and add a couple of repeater lamps with incandescent globes on the side, you may get away with only 10W. (Only for the flashers of course).
    Diana
    Cool......some clearance lights on my 6x4. Let me play around with the wiring on the weekend. Who knows....it may even diminish the pulsing.
    Jeff
    Hi All,
    Thanks,
    Jeff
    you can get load resistors that sit in parallel, yes parallel. Check with repco or the like. That will cure the little dash light not flashing but wont cure the pulse problem.
    Mine pulse as well
    Aug 2008
    Sunshinecoast QLD
    hi can you tell me if i will have the same problem with a new van that has bulb tail lihgts but led side lights
    Jeff, drop into MLR/ULR we normally have a few behind the counter for this problem. $295.00. We can show u one.
    If u need to ring me, direct 9684 1021.
