Results 1 to 10 of 31
Thread: Biodiesel
    Ipswich Qld
    Biodiesel
    Hello All,
    I have a 96 update TDI. When I was over in West Oz last year I used ,for the first time, Biodiesel . It was cheaper in a bout of higher fuel prices,134.9 against 145.9 a litre. The TDI performed brilliantly on it.The only advice that I can offer is to have a few fuel filters on hand as it certainly cleans the insides of the donk out.On start I had only blue smoke and very little against standard diesel very much on the black side. On bio it purred. Now that I am back on standard the black smoke has returned. The quicker we are able to get in all states the better is my opinion.
    Cheers and safe driving to you all.
    Last edited by Disco44; 21st October 2007 at 07:31 PM. Reason: Fixed it up to be more readable
    yep bio is great on the old school mechanical diesels....
    but please dont use it in td5's theres a lot of reasons not to (to have a WAG it should be ok to use up to say 20% to pick a nominal figure from OOMA) but based purely on the high pressure lubricity (or lack thereof) of bio and the excess ethers and other crud that has the potential to be harmful to your injectors and seals its just not a good idea.
    I will acknowlodge however that it is certainly with in the realms of reality to get a perfect batch of bio and blend in just enough addative to get the lubricity up to scratch and never have a problem with the TD5 but murphy just doesnt play that way with me.
    Cairns, FNQ
    Smile
    Dave....any mods/adjustments that should be done to the Isuzu, prior to adding Bio-juice to the tank?....
    short term or occasional useage no not really.
    if you were going to convert to full time usage Id add a second sedimentor in parallel with the first or fit a larger one and swap all the seals over for new ones.
    Depending on the quality of the bio you might want to back the injection timing off a degree or 2 but thats something thats probabley going to change from tank to tank.
    Id also keep a spare set of lift pump, priming pump seals and filters in vac lock bags on board untill your on about your 5th or 6th tank (who am I kidding Id carry that anyway)
    IMHO the suzie is a perfect candidate for bio.
    Hi Dave,
    Biodiesel has higher lubricity when compared to petrodiesel so would you mind just running through exactly what you mean by this?
    Thanks,
    Cameron
    Jul 2007
    Australia
    Gedday all,
    We've been buying diesel from our local servo now for a good number of years.
    Today I found out that they've been selling B20 - 20%biodiesel blended with petrodiesel - since about March this year apparently.
    So it will be a very interesting experiment with our 2003 td5 disco to see how it goes in the next 6-12mths.
    Details on the fuel can be found here:
    http://www.freedomfuels.com.au/
    I just hope I haven't jinxed myself by writing this.
    Peter
    Quote Originally Posted by cameron View Post
    Hi Dave,
    Thanks,
    Cameron
    sure...
    Yes at normal temps and pressures (lets say TDI300 engines) 100% pure and correctly refined bio IS the better diesel in all respects full stop end of story on that count.
    But... When you step out of the hypotetical perfect world Bio Aint Bio when its got water suspended in it that hasnt been dried out, ethers still in solution that havent been washed out and imperfections in the oil from using burnt oil.
    Now in a normal situation low to medium pressure injectors (relatively speaking here ALL injection is high pressure) the bio is great, and the contaminants arent a problem But once you switch over to the High pressure injectors (21K+ psi) you start to run into problems.
    First off the impurities cause little Islands in the oil between the moving part and the oil is expelled from the high points (lateral experiment;squeeze your thumb and forefinger together really really hard and put it in water, pull out, dry hand and when you pull your fingers apart the middle of the pressed together parts should be dry) that lack of lube causes problems. The knock on effect of this is if these contaminates causes an injector to fail to seat you will get dribbley injector or even worse a fail to close letting residual fuel pressure drain into the combustion chamber potentially hydraulicing the engine (not to bad for pots 1-4 but #5 doesnt have a glow plug you can pull out to vent it and I bet it will be the #5 that does it just to annoy you)
    Secondly the bio can attack some seals and the lubricity of it when its warm and under just a little pressure means it can leak past some seals that dino diesel just wouldnt have, not so much of a problem on a TDI as the injection pump is only at about 15psi or so max and the entire fuel system is external to the engineso you can see the problem and fix the leaks.... On a TD% however about 50% of your fuel system is internal to the engine, get one of them leaking and your lube oil gets diluted with fuel. That'll kill you in one of 2 ways, by diluting the lube oil to the point that the engine siezes OR by leaking out the turbo seal/ venting out the crankcase ventilation into the inlet causing a run away (havent heard of that one yet but on paper its plausable)
    The last way is with the effeciency with which Bio cleans. All the crud that was happilly adhered to the internals of your fuel system will no longer be so and you can get all of the problems from the first point but more likely will be the death of the fuel pump from having to pump the equivelent of gravel..
    All that said...
    I know of people who have run their TD5 on bio and are still doing so with no problems that people running dino arent having. But at $1700 odd for an injector, $1k for a pump, who knows how much to redo the head if it gets stuffed and how much? for a new donk if you get a run away. Bios not for me in the TD5...
    It might be doable in the new ford donk But I havent yet specked that one out and dont own one so Im not likely to....
    I do know that the old 2.25 runs just fine on dewatered and filterd cooking oil. did that in townsville for about 2 months as an experiment.
    Thanks for the clarification Dave.
    So from my reading it seems that the catalyst to problems developing (if they do) might generally be fuel quality issues related to insufficient filtering of impurities, water and incomplete processing. The rest relates to the chemical properties properties of the bio if those circumstances come into play.
    If I have picked up on what you are saying (and paraphrased accurately enough for you) then I can certainly live with that!
    As much as I love biodiesel I would always suggest that if you have a choice between good quality petrodiesel and poor quality off-spec biodiesel that you should go with the quality fuel everytime. We are lucky here in Sydney that we have an excellent commercial source.
    Happy bioing (I don't know if that is a word but it is now...)
    Cameron
    Gug Guest
    I've been told I should replace all the fuel lines in my '93 tdi 200 with something called vitton(?). Is this true and if so where do you get it?
    Gug
    Lesmurdie - Perth WA
    On a bit of a side issue, Approx a year ago I posted on this site the failure of a near new lift pump on my 200TDI after using B20. At the time the bio was considered to be the cause of the failure. This is not the case as I have had the diaphram soaking in 100% bio for three months and there is no indication of deterioration or damage.
