Results 1 to 10 of 11
Thread: This is number 3
    May 2003
    On The Road
    This is number 3
    there was a 1 and 2
    waddyarekon it is?
    Jun 2003
    Launceston, Tasmania
    You should remove the link attached to the photo before asking that pedro
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Apr 2007
    Central Coast NSW
    Is it a 'new' Muira.... nooks nice anyhow
    Does it go fast and make loud noises?
    RonMcGr Guest
    Quote Originally Posted by Phoenix View Post
    May 2003
    On The Road
    dammit I hate that!
    no cheating now----
    Jun 2003
    fixed the giveaway link
    1994 Discovery TDi
    Alstonville...is near Byron Bay
    was it a Holden (dream car) about 1971 as seen at the melb or syd motor show
    the style is of the deTomaso Mangusta, with a nice touch of the muira
    and, no I didn't see the links 'cause some party pooper knocked 'em
    looks like a curvy version of something that lives in my shed
    standing by, pedro
    and BTW, Pedro, mate, what was number one and number two (no toilet jokes here please)...
    the curtain backdrop is certainly cheap enough to be an aussie motorshow
    GQ
    May 2003
    On The Road
    This is a number 2,,
    May 2003
    On The Road
    AMX History Production of the AMX started in the fall of 1967 at American Motors' Kenosha, Wisconsin, plant. The AMC AMX (American Motors eXperimental) debuted on Feb. 24, 1968. The AMX 2-seater debuted as a 1968-1/2 model, based on the Javelin but with a foot chopped out of the wheelbase. The AMX wheelbase is only 97 inches, with an overall length of 177.22 in., a width of 71.57 in. and a height of 51.73 in. It weighs in at just over 3,000 lbs. 1970 was the last year for the true AMX. The AMX was the only American steel bodied two seater of its time. The starting factory price for a 1968 AMX was $3,245.00 and resulted in only 6,725 AMXs being built.. Before being introduced to the public at the Chicago Auto Show on February 23, 1968, the AMX broke 106 National and International speed records. Craig Breedlove took the AMX to Bonneville and rran an official 189 mph with an unofficial run of over 200 mph. To celebrate this feat, about 50 special red, white, and blue "Craig Breedlove" editions were built.
    Standard equipment on the AMX included reclining bucket seats, carpeting, woodgrain interior trim, E70-14 Goodyear polyglas tires, a four-speed manual transmission, and a heavy-duty suspension. Only V-8's were available, and those were all equipped with Carter four-barrels and dual exhausts. The baseline 290 ci produced 225 hp at 4700 rpm, the optional 343 ci produced 280 hp and the top-of-the-line 390 was rated at 315 hp with 425 ft.lbs of torque. (note: all AMC V-8s are smallblocks! the 290, 304, 343, 360, 390 and 401 engines are all based on the same block.) The 390 was capable of speeds close to 130 mph. Also there were Group 19 dealer-installed factory performance parts; Aluminum intake manifolds, hi-lift cams, roller rockers, Detroit Locker rear-ends with gears as steep as 5.00: 1, side pipes, and rear wheel disc brake kits, to name a few. Like the Javelin, the AMX could be had with a wide range of options, including the popular "Go Package", which included a 343 or 390 V-8, power front discs, redline tires, Twin Grip rear axle, and racing stripes. Plus the Airless Spare--a fifth tire that takes up little trunk space because it doesn't inflate until you need it.
    AMC also offered a number of luxury items. Air conditioning, automatic tranmission, tilt steering, power steering or quick-ratio manual steering, AM, AM-FM or AM 8 track stereo, tinted windows, remote outside mirror and power disc brakes were on the list of options. Reclining bucket seats were standard.
    There were few changes to the AMX for 1969. The base price increased by $52 and a new 140 mph speedometer was included in a new dashboard, which included a hood panel cover. A special series of "Big Bad AMX" were built mid year. The "Big Bad AMX" option cost just $34 and included wild colors with body colored bumpers.
    The 1968 and 1969 models were very similar, but the AMX received some styling changes for 1970, including a different grille and hood. The 1970 models also got a double ball-joint front suspension instead of the trunnion-based system found on the earlier models, a new 360 cid V-8 as the base engine rated at 290 bhp, "dogleg" exhaust ports, and a new Motorcraft 4-barrel carb. The 1970 AMX increased to $3,395. The front end and taillamps were also completely restyled. At the top of the hood there was a Ram-Air induction scoop. This would be the last year for true two-seat AMX production.
    The two seat AMX ended in 1970 as the 1971 AMX which was now technically the top of the line Javelin. 1972 saw small styling changes. Although the AMX would technically continue to 1974, this was the last year for muscle car engines and muscle car performance.
    Oct 2003
    Gold Coast, Qld.
    i know, i know... one more little giveaway you haven't hidden
    RAAF Tactical 200184 & 200168
