Results 1 to 10 of 17
Thread: 03 Def swivel hubs - oil or grease
    Oct 2006
    NSW Riverina
    I've had a search through this forum and can't seem to find the answer to my question. Are the swivel hubs filled with oil or grease? My RAVE cd tells me its a Texaco EP00 on the castrol Austraila site it recommends their CASTROL EPX 80W/90. Threads here talk about grease or some kind of mixture???
    Now I own a 12/2003 Defender 110 and am just wondering what I should use. I have read somewhere here about oil conversions for the hubs so this has got me totally confused.
    Cheers Rob.
    Feb 2005
    i have one of each....an each way bet
    oil - passenger side
    grease - drivers side
    a broke a driver side cv so i converted to one shot grease, i'm pretty sure if landrover service your car they would change from oil to grease...i reckon the latest models would be grease filled
    don't ask me whick is best
    Free Again Thanks Dan
    I like the oil filled setup
    Adelaide - Torrens Park
    If your swivel ball is grey teflon coated it will be grease filled. Chrome = oil filled. Unless someone has already changed it...
    Padstow NSW
    my balls were coated, more of a black ish colour, but they are now more of a silver colour??
    i use oil in both.
    cheers phil
    Oct 2006
    NSW Riverina
    I know mine are dark in colour and looked through the service history and it hasn't been changed so I would assume it would be grease. Is there a Australian marked equiv grease for this job?
    Rob
    Safety Bay
    I just overhauled my front end and grease came out so one-shot grease went in.The next weekend I replaced the front diff oil and it was full of one-shot grease so the inner seal was-is leaking so I don't thing it really matters. Pat
    NSW far north coast
    Quote Originally Posted by discowhite View Post
    i use oil in both.
    cheers phil
    and which colour does the wife prefer and was the colour change painful ?
    the easy way to tell if they came from the factory with 'Oneshot' grease (Texaco Molytex EP 00 ) is if your swivels don't have a level and drain plug. I think these were deleted around '97 or so with the introduction of the grease.
    An NLGI 00 grease is very light and runny, almost like a very viscous oil. Looking at the specs of the Molytex EP00 it is a very average grease with 3% moly.
    Adelaide Hills. South Australia
    Penrite 00 Semi - fluid Grease.
    Google for the Pdf
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by 4bee View Post
    Google for the Pdf
    http://www.penrite.com.au/files/2ZIIFZOTFD/SEMI-PIS.pdf
    Penrite used to specify Semi-fluid Grease for the swivels on their US Site however it no longer seems to be mentioned in the vehicle spec sheets.
    Semi fluid grease is also ideal for leaky steering boxes on series vehicles (non-power steering)
    Diana
