Took a new Defender for a test drive overnight
Well, I took the new Defender for a test drive overnight last week. Sorry no photos, but you know what it looks like. Drove for at least 3 hours straight on good roads, dirt roads, hilly roads and through a couple of paddocks
Really nice driving, good acceleration and great on the hills, but there are some niggles:
- There is an annoying flat spot when you put your foot down until the turbo spins up. This could be an issue when you expect to get power and there is none
- The gear lever has a spring thing that centres it between gears and if you're not quite quick enough you lose where you were, gear-wise
- Having the reverse up beside 1st wasn't very entertaining since getting into first requires a push to the left and reverse a slightly harder push
- Reverse gear is slightly high ratio'd, so the speed is too fast
- Low range first doesn't seem slow enough to me. I can see a market for under-drives
- Some finishing wasn't too good for a vehicle with its price tag; exposed wires in the cabin, glue smears, that kind of thing
- Power tops out at around 3500 rpm, but there seems to be more there that could be applied.
- It seems to be stuck in a middle ground of not being quite comfy enough for the soccer brigade and not rugged enough for the serious workhorse.
I didn't have time to pull the boat unfortunately, but I imagine it'd do ok there (weighs just shy of 3t) but not at any great speed.
In the end, after driving it and considering what we have now I don't see that there is any compelling reason to go out and buy one, especially new at $68k. Maybe I've been associated with computers too long, but the "never buy the first version" seems to apply here. To my mind LR needs to do more work on this to get to where it needs to be.
Just a few thoughts.
Alan
2005 Disco 2 HSE
1983 Series III Stage 1 V8
