Results 1 to 10 of 21
Thread: camshafts ? 4.0L
    bushytas Guest
    Camshaft Replacement Whos Done ONE
    Hi all ive been looking into cams today after talking to one or two people that said my engine might be better off with a new cam.
    My question is has anyone changed their cam for a High torque cam for 4wd and towing applications?
    crow cams sell one that has a really nice rev range 1000
    3900RPM
    Anyway let me know if you have changed yours and if you have changed to a grind thats not standard and what sort of differents its made to your engine
    Brendon
    Avoca Beach
    Tell them they are not accurate.
    Motor manufacturers spend millions on cam development.
    The 4litre cam is specifically designed for that engine.
    It is different to a 3.9. It has a more agressive profile.
    Ask Crow how much research they have done on a 4litre Rover V8 with GEMS. I will bet it's nix nada nil .
    Be careful what it does to vacuum as GEMS is a very advanced ECU, and modern ECUs do not like changed parameters.
    Cam makers have profiles usually developed many years ago, and applied to many different engines.
    There have been several threads on this forum in the past regarding poor results with aftermarket cams on injected engines.
    IMHO, the cam is the last thing you should change after exhaust, inlet, heads, maybe chipping the ECU or piggyback. I suggest that you ask a specialist (EG Graeme Cooper, LRA,) for their opinion. I know Cooper tested many cams with 3.9's before finding one they were happy with.
    Regards Philip A
    Apr 2007
    Mooroolbark, Vic
    Hi. Mine's a 3.5L. I've just put a Wade camshaft in (i was doing up the engine anyway and thought i'd try it).
    Works fine, sounds good, goes good. Haven't been offroad with it yet (will on the weekend). The power range is 2500-6000rpm which i think is a bit high, but i do tend to rev it high .
    My experience probably doesn't apply to you as much since its a different engine with an ECU...
    My engines in the process of being rebuilt and is being fitted with a new cam, well new everything actually, what started as a leaking welsch plug. Will let you know how it goes after I get it back and its worn in a bit. Its a long story - will most probably add it to the rants section at some point
    bushytas Guest
    Quote Originally Posted by Hobie18 View Post
    keep us informed and if your doing the build yourself can you post pictures.
    also what cam are you fitting got any spec,s for me
    ive been looking at a High torque cam for 4wd and towing applications rev range from 1000 too 4000 as i seem to sit around this range when driving and out bush.
    the only time its really over 4000 is when im in mud but then its sitting on the rev limiter lol rmmm rmmm rmmm love that sound its going to go rmmm pop one day
    bushytas Guest
    Regards Philip A
    will keep it in mind thanks
    the only reasion im replacing it now is its worn out so i just thought i would go for a High torque cam giving me just that bit more up hills . Living in tasmania as everyone know its full of hills and i find that the rover changes back gears a lot so i just thought it might hold on a bit more with a different cam
    We started to do it ourselves, but it went very pear shaped, and now the block is being heat treated etc - what started as a head gasket is now a complete rebuild, due to previous owner/s cooking the engine to the extent that most components were warped. So now the shop is doing it - at least that way I have some warranty. Believe a torque cam is being fitted the motor is a 3.9v8 from a 1990 rangie
    bushytas Guest
    who made the cam do you know ?? also whats the rev range ?
    Kingston, Tassie, OZ.
    Hi Brendan.
    Unfortunately, the P38a takes a very different cam from the other Rover V8's. The differences are at the front of the cam, and they are not interchangeable. Unless they have made the cam to specifically suit the P38a 4.0 and 4.6 engines, they won't fit. The reason is the Gems etc uses a cam angle sensor too, and this requires a different nose length and sprocket etc to the usual Rover V8 cam. Last time I cammed one, I had to fit a genuine standard cam due to the lack of availability.
    I would definately check with Graeme cooper, LRA or Bruce Davis performance in Sydney as to the availability of performance cams for these etc. as it was a while ago when I did the last one.
    JC
    My 4.6 has a high torque 3.5 cam with the nose cut off and remachined to suit the GEMS engine. Done in-house by Bruce Davis.
    Davis can convert your 4.0 to a 4.6
