Results 1 to 6 of 6
Thread: TD5 (new) injector programming in ECU in Sydney Area
    Afternoon Guys,
    I am about to fit new injectors (yes cost a bloody fotune) and want to know if you know anybody who can programme the new injectors into the ECU for me in the Sydney area, or do i have to go to a dealer for this?
    In addition to this, can I drive the Disco without having the injectors specifically programmed into the ECU?
    Thanks,
    Auke
    99.87 MB
    I'd give Davis Performance Landys a call. They're in Annangrove on Annangrove Rd.
    9679 1978
    Slunnie
    Padstow NSW
    peter davis roving mechanical
    should be able to do the job also, hes a mobile mech,
    0410503500
    and i dont think you'll be able to drive it till the injectors are coded to your ecu??
    cheers phil
    Thanks guys
    Slunnie, Disco White,
    Thanks for you help.
    I hope to have my baby running again this week so that I can finally join you (if you'll have a newbie) and the other AULRO members on some trips.
    Auke
    tombraider Guest
    Quote Originally Posted by discowhite View Post
    0410503500
    cheers phil
    Yes it can be driven....
    Just remember to write them down.... Before hand!
    At the worst, send the ECU and injector codes down and I'll code it for you.
    Pennant Hills, Sydney
    Tombraider is right you can drive it and you may not notice any difference the codes alter the dwell timing (hope I got that right) for each injector, changed mine last year picked up a set for $950 kept the old ones for spares
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
