assuming you want to know how to do it using a timing light....
same as you do it on any other engine. On the front pully is a timing mark hook up your timing light to the battery and #1 plug lead (paying attention to orientation of the clamp) and then start it up, point the light at the front pully, pull the trigger and your set to fiddle with the dizzy position to get the timing.
Remember that your initial timing should already be done and that you need to first set the idle speed (600rpm from memory), disconect the vacume advance unit and plug the engine side of that line before setting off on this merry adventure. 8 degrees Before TDC from memory in this configuration which should jump to about 12 when you plug the vac line back together.
