Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 123
Thread: 1985 County "Upgrade"
    Wheelers Hill, Melbourne
    I purchased a rolled over 1985 County that had the works including a 350 chev fully engineered and wanted to swap the good bits from my County over to this one.
    The firewall has what I describe as minor damage so it will remain.
    I intend to do this over a fairly long period, so I will only update this when significant work is achieved.
    The rolled County was stripped out of fuel tanks, seats, wheel carrier, bullbar etc but the workmanship is aircraft standard, so I have diverted from wanting to put the engine from the rolled one into mine to putting the windscreen, body etc over to the new purchase. For ease of identity I think I'll call them red and white.
    Having a few probs uploading, still can't get it right.
    This is after week 1
    Doors, roof,floorboards, rear of gearbox & front hub removed. pic of rear output shaft that caused the rollover, it is a 5.7 litre donk after all.
    Firewall straightened & back to bare chassis at rear
    Gas tanks and fuel tanks swapping over are the next job
    Singapore via Melbourne
    stripey apron time
    I like the hand winch + oxy technique for straightening it out
    Well, I got sidetracked- again. I got cold feet when it came to pulling my County apart, so for $350, I bought a series 3 off a wrecker. That way I can put the cab & tray on the project County, take her for a spin or two, and if I'm happy, then probably get stuck into the county body and put it over. Decisions, decisions..
    The series 3 arrived home, now I gotta remember how I maximised these pics ???
    I'll try to post one of the chassis
    OK here is the stripped down series 3
    GRRRRR I think this puta is pulling my chain
    Cabin fits the existing brackets ok, i just needed to reverse the brackets that normally hold the back of the floor.
    See arrows
    This gives an extra 150mm of cabin space, however I need to extend the cabin, canopy & roof.
    Marking out the side panel, I will use a rear panel as infill.
    Hopefully these upload ok
    OK, I think I've got this picture stuff down pat.
    I grafted the cabin over by reversing some brackets. This gives an extra 150mm cabin space, but now I have to add some fill in to the cabin. Pics are -
    cabin in place
    1 of the brackets is reversed to illustrate.
    Marking out where to cut
    [/IMG]
    [/IMG]
    [/IMG]
    David
    thats a bloody nice looking series chassis, going to be any left of it when you'r done? I know some people that may not be paying attention that might want some sections of it
