Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: isuzu diesels
    isuzu diesels
    Isuzu have made a lot of decent diesel truck engines, is there a reason to use a 4BD1 or 4BD1-T as opposed to the 4HG1 and 4HF1 engines?
    Kiwiland
    Quote Originally Posted by dobbo View Post
    The main two reasons would be size and no electronic control.
    IIRC the 4H series are OHC which should make them taller than the pushrod 4B series.
    Without being familiar with the other engines, I suspect the main reason would be fitting them in, with a secondary point being compatibility of the torque curve with available gear ratios.
    The 4BD1 is pretty much of a shoehorn job, and the major problem is likely to be engine height, with clearance on the bottom for the front axle housing and prop shaft while retaining the same crankshaft alignment. For example, the 4BD1 needed a different sump and oil filter setup.
    Brisbane, Inner East.
    Isuzu used to make a 3.5 litre six cylinder lightweight diesel engine for Thermo King who used it on their semi-trailer refrigeration units to replace heavier engines that were pulling the front out of the newer light-weight fibre-glass reefer vans. Thermo King used to show it as a Thermo King engine on their brochures. I have long thought this would be a great repower for a number of vehicles. One may need a different governor on the injection pump for variable speed use. Someone with more knowledge than I may be able to answer this.
    URSUSMAJOR
    mcrover Guest
    I was reading a bit of stuff from the US on the 4BD2T which apparently is basically the same block but a different head and is intercooled.
    They apparently replaced the 4BD1 and built from 92 to 98.
    Does anyone know if these engines were available in OZ as this could make getting a conversion to an update Disco 1 or Defender re power past EPA/ADR regs a bit easier.
    Cairns, FNQ
    Unhappy
    'this could make getting a conversion to an update Disco 1 or Defender re power past EPA/ADR regs a bit easier'
    Didn't realise that this was a problem, does anyone have any more information on this?.
    Kiwiland
    Quote Originally Posted by mcrover View Post
    4BD2 is indirect injection which makes it quieter but less efficient and slower starting. Th 4BD1T is more reliable too.
    I have a turbo and manifold off a 4BD2 (same as the later 4BD1 turbo and manifold) which cracked it's head.
    mcrover Guest
    Quote Originally Posted by 1103.9TDI View Post
    I only say that as they tend to frown on dropping in a older engine into a newer car.
    Rovercare (Matt) says it's possible, Im assuming you would need an engineers cert but you would anyway for an engine conversion I'd think but Im not 100%.
    I know bugger all about these engines, I just thought it was interesting.
    Cairns, FNQ
    Smile
    Just interested, the RTA may have an issue with the engineering of larger a capacity engine being installed in a vehicle with an original engine of a smaller capacity, thats a given. But if the EPA become more concerned about exhaust or crankcase fuming and/or noise polution on older diesels.........Greeny appeasing........that may spell an end to older diesel engines being installed in newer vehicles totally.
    Kiwiland
    In that case, you'd want to install the 4BD1T in a vehicle that had the 3.9 V8.
    I'd support emissions standards and testing happily, but not limitations based on age or country of origin.
