Results 1 to 10 of 15
Thread: Any metalurgists out there ????
    lokka Guest
    I have a question which would be beta for making steering linkages solid 32mm 304 grade stainless or will the 32mm od 20mm id 4140 chrome molly be tougher im leaning towards the solid stainless as it should be strong enough but would like some opinions please
    Thanks in advance
    Yinnar South, Vic
    Quote Originally Posted by lokka View Post
    Thanks in advance
    The stainless wont be real good for the threads on the tie rod ends
    Apr 2002
    Bellara 4507
    32.43 MB
    Quote Originally Posted by rovercare View Post
    what he said...
    nothing grabs worse than stainless, it would cause all sorts of grief...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    go with chrome moly tube.
    tube is stronger than bar and use 4130 aircraft tube.
    and expect to pay for it.
    get a real qulified welder, not anyone that says they can weld
    and of course you will get engineering approval for it, or void your insurance if it fails.
    Safe Travels
    harry
    Most grades of stainless are quite unsuitable for any steering components, as it work hardens and cracks - they also work harden when doing machining such as thread cutting, making this operation much more difficult.
    The solid/tubular is a different question. The solid will be stronger, but the difference is probably insignificant for the dimensions given - the middle bit does not add a lot to strength in compression (it will fail by Euler buckling), or in bending given a blow from a rock or stump, which are the probable failure modes.
    Brisbane, Inner East.
    Thanks in advance
    Call Mal. Leslie at S.G.Leslie and Sons, 15 Mologa Rd. West Heidelberg 3081, 03 9459 2859. He does severe service tie rods and track rods for LR/RR. I sold him the special taps and dies. If doing them yourself I would use the chrome moly. tube. Stainless is a fair B. to thread, being very tough and habving four times the co-efficient of friction of mild steel. Easy to break threading tools on it, and it also wears them out.
    URSUSMAJOR
    Yinnar South, Vic
    Quote Originally Posted by harry View Post
    Weld?? just boreing and taping
    lokka Guest
    Ok looks like the stainless is not the way to go then i understand how hard stainless is and i know it work hardens i just thought it would be ok to use in this application thanks to all who have posted its good to get a few different opinions and as for welding them i wont be doing that tho if i had to im more than qualified for welding just about anything
    Ok looks like the stainless is not the way to go then i understand how hard stainless is and i know it work hardens i just thought it would be ok to use in this application .......
    Just think about the hammering it gets as a wheel goes over, for example, corrugations. And visualise a crack starting from a thread root........
    lokka Guest
    Yep i understand were ya coming from john ive worked with stainless for quite some time now and i understand how it becomes brittle and can fracture just didnt think that it would in this case tho ah well il hunt down some chrome molly tube or solid bar insted andithink the solid would be the stronger option tho probably dearer than tube
