Results 1 to 10 of 18
Thread: Dazzling new toyota technology
    Williams West Aust
    Hows this???
    Just read an article about the new 200 Series Landcruiser.
    It fitted with an all new suspension system they call KDDS Kenetic Dynamic Suspension System,yep the words dont even matcg the acronym
    Designed and developed by Kinetic suspensions WA.
    Now this BRAND NEW technology giges increased off-road articulation and greatly improved road holding.
    HOW IS THIS SO??? Well they have come up with a real clever idea,fit a hydraulic ram to the front and rear stabiliser bars,add a computer to control the pressure applied via the rams to increase/decrease pressure on the stabiliser bars.
    WHAT A FANTASTIC BIT OF ENGINEERING.
    Ive got it on my 1999 D2,Landrover call it ACE,active cornering enhancment.
    WELCOME TO THE MODERN WORLD TOYOTA
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Redland Bay QLD
    How about a quick check of google and the kinetics site eh?
    It IS actually KDSS, and waaaay fancier than ACE. Also in simplest form, probably more reliable.
    Kinetics generally make good ****. Atleast for racing purposes.
    The coloured lines are hydraulic.
    mcrover Guest
    I was reading about this in 4wd mags back in about 97.
    They have fitted it to Unimogs, Landrovers/Perenti's and Nissan Patrol's (GQ) were the test rigs at the time and they were having trouble with getting a computer system to work as fast as the Hydronumatic system could.
    It was pretty amazing what they could do with it but no matter how good technology is when it's new, it will fail eventually as all parts do and it is 1 thing that you cant do without is your suspention.
    At least with a coil, worst comes to worse you weld it up and keep the guts off the ground.
    Andrew Richmond (LRA) ran a much more crude system in his old orange rangie back in about 2001.
    Nothing all that new but just updated Id say.
    Cairns, FNQ
    Cool
    I had a similar system fittted to my '87 County when I bought it!; it had a ram on front left and rear right of a special anti-roll bar, that pushed/pulled via a pendulum that opened/closed a hydraulic valve, so as you went around a corner, the pendulum would swing opening one route for the fluid, and closing the other. The system was fed by a separate hydraulic pump/reservoir via the A/C fan belts. It was great for high speed cornering-highway use, but found it too restrictive off-road & removed it. I've seen advertisements in old 4WD mags from the early eighties, for these units, they are definitely nothing new, and were available for any 4x4 of that period!. Apparently they were hideously expensive!.
    'ACE'-old technology with a tweak.......probably unrealiable long term.....
    I have an idea -
    4 hydraulic rams (1 per wheel) all linked to a common reservoir.
    The reservoir itself is a bigger hydraulic ram with a coil spring providing tension (pushing in) to the reservoir ram. The coil spring mounting plate has a screw mechanism which allows for more or less spring tension on the reservoir.
    This way the movement of one wheel is partially compensated for by the other three, while the reservoir (larger bore, lower resistance) offers additional dampening and takes the harshness out of any maneuver.
    The adjustable spring not only allows for stiffening the suspension, but also for raising it.
    Now if only I had the workshop to build it.
    CROMER, NSW
    typical of toyota. copy what LR does about 10 yrs ago and claim it as their own. if compared to LR all they'll say is that what LR came out with was primitive and rudimentary compared to their much improved system.
    but i read something interesting in the herald today;-
    'Quick' response on Toyota quality issues Toyota is "mortified" that its recent quality glitches have tarnished the company's reputation for well-built vehicles. A series of embarrassing quality issues has led to service campaigns to rectify problems in recent months, rocking a company renowned for quality and reliability. good to see some of their many shortcomings are being noticed
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
    so you mean it gives a bit of a lift via hydraulics
    like LR did with pneumatics years ago?
    well whoop-de-doo
    Quote Originally Posted by HangOver View Post
    well whoop-de-doo
    Or perhaps something like Citroen introduced more than fifty years ago? Maybe their patents have expired.
    CROMER, NSW
    no! the hydraulics simply put pressure on the side/corner that wants to dip when cornering to keep the car level. has nothing to do with suspension height.
    LAND ROVER;
    Padstow NSW
    Quote Originally Posted by barney View Post
    so dose that mean that there will be no more toymotas driving round like the 100series dragging their front bars on the ground
    cheers phil
