Results 1 to 6 of 6
Thread: injectors on tdi
    May 2006
    Ulverstone,TAS
    injectors on tdi
    Can you guys tell me when I should replace my injectors?
    Is it every 100k's/200k's ?? .
    Mines starting to run a little fast on idle after driving for 10/15 mins.
    Gazza
    Bairnsdale enjoying the rural view no rooftops to see here
    if you do a search you will find several threads on this subject
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    brisbane
    I've just replaced mine at 335k. Worthwhile improvement in power. Assuming economy too. Only did it 2 days ago.
    Tony
    Warburton, Victoria
    Quote Originally Posted by littlecub53 View Post
    Gazza
    What model? Disco, Defender? 300tdi, 200tdi, Td5???
    Injectors should not cause fast idle when warm
    NSW , Pennant Hills
    Hi Mate;
    How many K 's has your Engine Done?
    has injectors ever been serviced ?
    you may not need to replace them !
    It may be just as simple as adjusting your Throttle cable to wind back your idling speed? how Fast is she idling?
    More info required...
    May 2006
    Ulverstone,TAS
    Smile
    Hi Disco_owner,
    Have already adjusted the throttle cable--still runs faster(usually around 900-950 rpms).Throttle is NOT sticking anywhere.
    Had the injector pump repaired 75k ago.
    Hi Sclarke,
    Sorry mate --its a disco 92 tdi manual.
    I've done 320k's
    Will trawl thru the tech section and see what I find.
    Thanks guys.
    gazza
