G'day Sam;
your main Cranking battery and the 2nd battery which is also another Cranking battery can be hooked up in paralell, no issues there. but If you are running a Fridge at a camp site it will be drawing from both batteries,so be warned !
some fridges eg Engels have a Cut off switch to stop Drawing current from your parallel battery set up when total voltage drop reaches a Certain voltage ,think this may be about 10 volts so that if you are on a camp site
running camp lights / fridge etc you will be able to start your car next morning with some power left in both batteries , however not all fridges are fitted with this device , so be careful not to Drain your batteries if you're static at a camp site.
I heard someone from our 4wd club mention this a while back that this actually a Prefered installation for most people who set off out push for weeks on end,No voltage sensitive relays / Electronics to control the charge patterns , the alternator is charging both batteries all the time.
However as an alternative option you can install a Manual Switch which allows you switch between your Main/Aux/Both.
