Page 1 of 11 123 ... LastLast
Results 1 to 10 of 101
Thread: what to do when your lift is a little higher
    Jun 2007
    Minchinbury NSW
    G'day all
    needs some help after installing my suspension on my Disco 2 I now have 5 inch lift on the front and 4 on the rear
    two options are
    option 1 is to place 1 inch spacer on the rear to bring the rear up
    or
    Option 2 is to pull the front springs out have them reset
    problem with option 1 is that Im pritty certian that the front ACE is going to bind up to over come this maybe I can install some Disconct sway bar links
    Problem with option 2 is if Dobinson reset my spring then the coils will be tighter and give bugger all arc
    what to do
    North West Tasmania
    Coils are cheap I would buy another pair to suit what you want.
    Save a lot of mucking around resetting coils, leaves are easy coils are a fair bit different.
    Zute Guest
    Resetting spring height does not change the stiffness. Its the length of the wire and its diameter.
    Are you sure you put the springs in the right ends ? (front rear)
    With that much lift it will change the front caster, which will need addressing.
    Stockton, NSW
    Quote Originally Posted by ROVERNIT View Post
    G'day all
    two options are
    or
    what to do
    Well, you are planning on putting in a winch so it will even out the lift when you do no doubt, for now, get some coil spacers or a spacer plate to go under spring seat for the rear just to even it out and get longer ACE rods made up, thats probobly the easiest and cheapest way, chances are if you get sshorter front springs you will end up replacing them after sag with the heavier front end when the winch comes along.
    Jun 2007
    Minchinbury NSW
    the hight it self is OK it drives well other then my shocks being a bit to soft
    it doesnt pull at all but bouncy the steering wheel sits to the left a bit to which is another issue that needs to be looked at
    I know that when in low gear the ACE deactivates giving the best Arc it can but even so with the diff moving up and down wouldnt the hydrolic arm have its limitations
    Stockton, NSW
    Quote Originally Posted by Zute View Post
    heheh thats what i was thinking when i saw pics of it!
    Stockton, NSW
    no doubt it has its limitations but only one way to find out if your setup is reaching them, find a ramp or something to flex it up on, get it flexed up as far as it goes then chock up the wheels and get under and have a good look at whats limiting the travel, if the ACE bars are holding it back then disconnect them to see how much more travel it has if it needs it extend the rods from the ram to the diffs, if its the shocks at there limit then thats all good
    99.87 MB
    The D2 front springs wont go into the rear. All springs have ground ends except for the front bottoms which are cut and dog legged.
    Slunnie
    Jun 2007
    Minchinbury NSW
    what does the caster do, does it adjust the diff angle or the steering geometry as it doesnt pull at all
    As for reseting thats the problem if the its reset then the coil gap is made smaller which will result in less flex
    the right ends are put in as the rear and front have different ends rear are flat top and bottom the front are flat top and kink in the bottom so that ok to
    Jun 2007
    Minchinbury NSW
    well thank god for that I can strike that out
