Results 1 to 10 of 33
Thread: Att! 2007 Defender engine sump gets damaged
    Ruslan Guest
    Original source viermalvier.de
    I'm not skilled in German, may somebody can give better translation. In short words, while offroading (articulation) a cross-flange joints get in touch with engine sump. More chance when steering wheel full lock right (?) Looks like design error
    Damaged:
    Fixed:
    Ruslan
    Melbourne, outer South East
    whoa ....that look like the uni to the front diff hits the sump on full LHS suspension compression ........
    Free Again Thanks Dan
    Oops thats not like LR to design a fault into a car
    There must be more than one fault
    willvine Guest
    Holy dooly, was there any mods done to the suspension from factory such as longer shocks.
    Avoca Beach
    Er, unless I am very mistaken, the drive shaft goes only up and down, not side to side by about 80MM.
    Thats why there are chamfers.
    He has hit what is technically called "a rock". The damage even looks like it was caused by a rock.
    Unless the engine mounts are so loose it can move about 80MM sideways.
    But what part of a Yolk is sharp enough to put punture holes in a sump?
    Regards Philip A
    Mar 2007
    Supposedly Land Rover Germany has issued a statement that a replacement sump (different shape), providing more clearance will be available in mid to late November.
    The truck in the photo was lifted, but apparently that was not the issue. The same thing happened to a number of others with stock configuration.
    There is some discussion as to weather this problem is unique to left hand drive '07 Defenders or not.
    East-South-East Girt-By-Sea
    1.20 MB
    Using Altavista Babelfish - Yuk!!!!
    "If one the Td4 more highly and NO adjustable Panhardstab blocked can happen when full bouncing the following!
    It goes thus very closely too with the Td4 at the oil pan."
    Greetings
    Peter
    YESTERDAY AFGHANISTAN, TODAY IRAQ! AND MORNING THE WHOLE WORLD? BUSH STOPS!
    Reply from Caruso:
    Why can that happen?
    Has no oh notices?
    Which part is there reingesemmelt?
    No alcohol is also no solution.
    Reply from Selbermacher:
    moment times..., cannot be nevertheless.
    what should that be original for a long time panhardstab to it debt?
    in former times everything was better!
    Back to Peter:
    It is the cardan shaft laterally into the tub strikes.
    M.E. does not go the Panhardstab yet over the zero point if it hits.
    I had know-eat from several such damage only THESE gave it with pictures.
    Since need it and one will see on which it to remachining runs out. I have tomorrow a Td4 in the workshop and times a pair thought on this topic will waste.
    Perhaps there is soon a hp oil pan.....
    Peter
    I think I understood more in German!
    Nanny state UK...
    Nah... There's more to it than just being under full articulation.
    M
    1.20 MB
    Back to Peter:
    Peter
    I get the impression that Peter has lifted his vehicle and didn't put in a longer (or adjustable) panhard rod.
    With the vehicle on full articulation the original panhard has pulled the double cardan joint into the sump.
    Goes to show you can't lift the vehicle without setting-up everything properly.
    Ellendale Tasmania.
    That's interesting they now have a double cardan front shaft like the D2
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
