Results 1 to 8 of 8
Thread: Defender rear door
    Bray Park, Qld
    Defender rear door
    I have a 99 defender. After coming back from trips on rough roads and having to weld the spare wheel mounting in the back door, I bought the Kamar spare wheel carrier.
    I understand the rear door was changed in 2002. Did that fix the problem? If I go to the new defender, should I take the carrier off and put It on the new vehicle? The other benefit was that it may have reduced the dust a bit (though not much).
    Lofty
    Feb 2005
    g'day from just across the hi-way.....we have probably exchanged waves
    wheel carriers are not cheap so i would look at taking it with me......just remember to keep the old bits
    the door on my 95 has been welded numerous times andhad the bracing kit fitted.....the spare now sits on the bonnet
    Orange NSW
    My 94 used to break the frame so I had steel plate welded right across the top of the door frame below the window and down to the "H" frame and through the "H" frame inside the door to more evenly spread the load.
    All the plates where cut to fit inside the frames, flush with the surface so the door trim went back on nicely.
    Never a problem since and a lot cheaper than a wheel carrier.
    Steve.
    Douglas Park, NSW
    The rear door did change around that time & while I haven't seen any cracking on the new doors, it's still a lot of weight hanging off it.
    I'd change the carrier over to the new car.
    May 2002
    Sydney, Australia
    new 1 piece doors are great - just be careful to check if your wheel carrier fits the MY02+ doors:
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    May 2002
    Sydney, Australia
    hey Scouse - the MY07+ Defender rear door the same as the MY02+?
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Eidsvold QLD
    my 03 model had the rear door repaired twice under warranty and then finally the wheel mount cracked through, go the carrier.
    Douglas Park, NSW
    Quote Originally Posted by LRHybrid100 View Post
    I'd have to double check with Parts but I would imagine so.
