17th November 2007, 07:50 AM
Td5 and a gushing of air
OK, I can now describe what it is I am hearing when my '03 D2 is on boost. It sounds like a mass gushing of air and mayby, 'maybe' an ever so slight rattle.
This may or may not be related but I have noticed that on hotter days it tends to want to kick back a gear when at the foot of slight inclines. However, this only happens sometimes. For example, on one of the days it did this i was heading up the coast and it kicked back a gear or two on the up side of the Mooney Mooney bridge. On the way home, temps were a little warmer and it powered up without the kickback no problemo...and overall, it felt more powerful. So really hard to get a recurring pattern...
I had an issue like this in my track car when I had a crack in one of the silicon hoses going to the intercooler.
So it could be crack in one of the pipes?
I also thought it could be a buckled exhaust manifold which I have read is not uncommon. I did take off the turtle shell and hand felt all of the nuts holding the manifold...none of then moved at all and they all had the same sound when I tapped them with my nail. Basic test I know, but it does/should work.
I am going to check the silicon hoses today. A visual inspection at first followed by a pressure test. I found my track cars cracks in the silicon hose with the pressure test. I have also heard that the hoses can delaminate from the inside....
Any other thoughts on what this gushing of air when on boost could be?
Caine
17th November 2007, 03:20 PM
Have you checked your turbo output pipe at the rubber flexible joint for leaks?
This may cause what you are describing.
17th November 2007, 08:01 PM
Well, problem found and soon to be solved. It's a split intercooler hose....same issue as on my track car....
Order has been placed....
