Results 1 to 6 of 6
Thread: fuel pump types
    99.87 MB
    fuel pump types
    Gday all,
    As many of you know, I'm running a 3.5V8 in a IIa.
    The IIa came with an electric fuel pump, and I'm wondering if it's a recognisable pump, and if so is it able to fuel a 3.5 or was it really only a 2.25 pump?
    TIA
    Slunnie
    Williams West Aust
    Hi Slunnie
    Obviously the 2a was a 6cyl originally.
    These pumps were painfull at the best of times,possibly why they were a double so you flicked over to the second side for emergency.
    I ditched mine,fitted an electronic inline(Faucett I think was the brand) and never had any more problems.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Avoca Beach
    AFAIK , that is a Facet electronic, although there are some Mitsubishi pumps that look the same.
    Some mechanics put them in instead of replacing the Facet "tick -tick"
    Regards Philip A
    Williams West Aust
    I think you are correct Phillip,I didnt look closely at the pic first time around!!!!
    the smaller Fawcett does up to 4.5L motors,then there is a bigger one that does up to 6.5 lts,so it should be good!!!
    Andrew
    99.87 MB
    Excellent, thanks for that fellas. I thought that I'd better just check before tearing other things apart.
    Slunnie
    Warburton, Victoria
    Yep a Facet.....
    Get a replacement one from Repco for about $50
