29th November 2007, 09:44 PM
Ig combo/switches
Can anyone tell me if a PCL6 switch will fit in place of the later Series1 or 2 switch, is the hole the same? anyone ever seen a solid brass PCL6 switch, I won it on Ebay for 15clams, coming from NZ apparently is real nice the pic I seen It looks fairly unique, should look ok in the Blue Streak
30th November 2007, 06:06 PM
G,day Graceysdad,the later series 1-2 ign switch is smaller in diameter but there should be no problem opening the hole out in the panel,cant say i,ve ever heard of a solid brass one sounds interesting.also it is a PLC6 switch.
good luck with it all.
1st December 2007, 09:08 AM
G'day Graceysdad
The original headlamp switch for the 86/88/107/109 was R239570 (Lucas LU031369) or for the US dollar areas R240714 (LU 031412) you could try and check with Kevin Baker @ KB Classic Parts,(07)54 944 221 (no internet)as he is the "Lucas Man" suppies most of the Vet/Vintage people
