Results 1 to 9 of 9
Thread: whats uploading?
    May 2003
    On The Road
    whats uploading?
    I have a little app that shows up/download speeds,,
    this arvo it was showing a small but constant up load of around 5kbs WITH a smaller download of around 4kbs,,
    I played around inside my firewall but nothing that had upload authority was open,,,
    is there a program that tells me exactly what program is uploading stuff?
    yes, I've already thought the worst but all my virus stuff came up clean--
    Jimboomba, QLD
    From a command prompt, type:
    netstat -b
    This will output the active connections and the executable associated with the connection.
    -- Paul --
    | '99 Discovery Td5 5spd man with a td5inside remap | doesn't know what it is in for ...
    | '94 Discovery Tdi 5spd man | going ... GONE
    May 2003
    On The Road
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\GUINESS>netstat -b
    Active Connections
    Proto Local Address Foreign Address State PID
    TCP bluey:1025 localhost:44334 ESTABLISHED 2276
    [kpf4gui.exe]
    TCP bluey:1033 localhost:1038 ESTABLISHED 2276
    [kpf4gui.exe]
    TCP bluey:1038 localhost:1033 ESTABLISHED 1048
    [kpf4ss.exe]
    TCP bluey:1052 localhost:44334 ESTABLISHED 3168
    [kpf4gui.exe]
    TCP bluey:1055 localhost:1057 ESTABLISHED 3168
    [kpf4gui.exe]
    TCP bluey:1057 localhost:1055 ESTABLISHED 1048
    [kpf4ss.exe]
    TCP bluey:3303 localhost:3304 ESTABLISHED 3752
    [firefox.exe]
    TCP bluey:3304 localhost:3303 ESTABLISHED 3752
    [firefox.exe]
    TCP bluey:3306 localhost:3307 ESTABLISHED 3752
    [firefox.exe]
    TCP bluey:3307 localhost:3306 ESTABLISHED 3752
    [firefox.exe]
    TCP bluey:44334 localhost:1052 ESTABLISHED 1048
    [kpf4ss.exe]
    TCP bluey:44334 localhost:1025 ESTABLISHED 1048
    [kpf4ss.exe]
    TCP bluey:3696 192.168.0.1:49152 ESTABLISHED 948
    c:\windows\system32\WS2_32.dll
    C:\WINDOWS\System32\WINHTTP.dll
    [svchost.exe]
    TCP bluey:1940 uslec-66-255-53-12.cust.uslec.net:http CLOSE_WA
    IT 1596
    [untray.exe]
    TCP bluey:3492 ip202-182-124-178.voicevalley-networks.com:http
    CLOSE_WAIT 3752
    [firefox.exe]
    TCP bluey:3485 ip202-182-124-178.voicevalley-networks.com:http
    TIME_WAIT 0
    this is all that shows up---
    the last 3 or 4 not sure about---
    Jimboomba, QLD
    Is Kerio the only firewall you are using or is the Windows firewall turned on still?
    If you run netstat with you browser, mail etc closed, it will give you an idea of any apps that are keeping a connection active.
    -- Paul --
    May 2003
    On The Road
    D'oh!
    What's the app?
    May 2003
    On The Road
    Its called Bitmeter
    and when I shut down
    Generic Host Process
    the up/down stops
    St Helena,Melbourne
    4.28 MB
    Sounds like a bit torrent program, i had a similar problem but now i shut down the program once i have finished.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    bitmeter info here
    Codebox Software - BitMeter
