Results 1 to 9 of 9
Thread: wanted pics of inside the back of 107" wagon
    LRO56 Guest
    Does anyone have any pics of the inside back part of a wagon
    Does it have the Bolk head behind the front seats and are the rear seats troopie style?
    LRO56 Guest
    My plan is to turn my 107" ute (wich was a wagon) Back into a wagon and need a camper type set up with a bed in the back and thinking the rear doors could be a problem.
    Thomas is also somthing i would be interested in,you could make it walk through cab with canvas side
    East-South-East Girt-By-Sea
    1.20 MB
    107" Station Wagon stuff
    Has your vehicle had a replacement rear cross member at some time? It is difficult to see but appears to be a standard tapered cross member.
    Take a look atthe 107 wagon section on Trans-Tasman Series 1 Forum you may find some pics of interest. (You may even join)
    Yes there is a bulkhead behind the drivers position.
    the seats in the 2nd row seats are very similar to the series 2/3 station wagons, except they can fold down to make a bed.
    Diana
    LRO56 Guest
    Thanks Diana,The folding rear seats sounds good,also that pic I posted is not mine just an example off something i would like
    LRO56 Guest
    This is the one I have
    This seat was in the ute is it the rear seat you`ve mentioned?
    And these seats were in the front
    Jun 2003
    Launceston, Tasmania
    If you are looking at making a camper have a look at some of the doormobiles. most of the interior equipment that they used was from kombies I am led to believe.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    1.20 MB
    Quote Originally Posted by LRO56 View Post
    ..... This seat was in the ute is it the rear seat you`ve mentioned?
    ..... And these seats were in the front
    Now that is more like it - it is a real pity, there was until recently a 1958 109" original ute made into a camper, using the body bits you are missing sitting in a yard in Nowra.
    The back seat looks to be the correct animal - you would have to ask Dennis or Ian on the TTS1 forum about how they work - not my area of expertise unfortunately.
    The seats in the front - the brown ones look to be series 2 Deluxe trim seats or seats recovered to look that way. However the seat fitted in place under the blue cover could easily be the correct seat back - although they had individual seat cushions the same as the rest of the series 1's
    Diana
    RonMcGr Guest
    These are what Phoenix was talking about.
    Dormobile
    Dormobile Brochures
    TeriAnn's "The Green Rover" 1960 Land Rover Dormobile
    Land Rover Dormobile pictures 5
    Interesting pics in this one:
    1970 LAND ROVER DORMOBILE CAMPER
    Nov 2007
    Cedar Grove SE QLD
    Thumbs up Series One 107 wagon
    Hi if you wan I have a pair of 107 station wagons, one is striped down to a bare chassis awaiting futher restoration while the onther is as found and still has most of the orignal trim if you like I can take a few picks of the rear section, doors and stuff.
    Cheers Brendon
