Muppo,
I fitted the LR Raised Air Intake (RAI) because at the time the Safari snorkel was not available. I chased Safari for about 1 year and finally gave up with all the delays.
Please note the LR version is not a snorkel like the Safari one. It is a Raised Air Intake and can let water into the air intake if you were sitting in water long enough. So determine what is most appropriate for your needs.
I can say that the LR RAI does not create any wind noise or whistling at any legal speed. If you have the window down a bit you will hear some sucking noise but that is about it. I do prefer the integrated look of the LR RAI over the Safari snorkel but if I had to make the choice again I'd go a Safari snorkel to be 100% sure in a deep water crossing. I can't comment on the Safari's noise factor.
Chris
It doesn't seem to make a lot of wind noise at higher speeds
