Results 1 to 10 of 29
Thread: What's your internet speed?
    Maleny, Queensland
    Question What's your internet speed?
    Just curious to know what data transfer speeds people get on what kind of connection.
    I'm currently getting just over 400kB/sec (3200kb/sec) on Telstra Bigpond Cable (and doing this at the same time). Pretty damn good and it means I'll have two more episodes of Top Gear down in less than an hour. Cable does seem to fluctuate depending on how heavy the neighbourhood usage is. I guess everyone must be at Church or something.
    not fast enough....
    NSW , Pennant Hills
    Quote Originally Posted by solmanic View Post
    that's good speed.. I get around that speed on ADSL+2..I have hit 700 KB/s at times , ... I assume that you use Utorrent to download Top gear..
    okay if you really wanna get technical , I'm about 600 meters from Telstra's exchange and often connect to TPG DSLAM at 22.6 Mb/s
    3 different Broadband speed tests.
    test 1)
    Sprint D/L = 3080 = Kb/s U/L = 390 Kb/s latency 128ms
    test 2)
    Speakeasy D/L = 2147 kb/s U/L 682 kb/s
    test 3)
    Megapath D/L = 2664 kb/s U/L = 743 kb/s latency 110 ms
    these site are in states
    from Ron's speed test site below ( great site Ron ) , here are results
    Test run on 16/12/2007 @ 07:51 PM
    Mirror: aaNet
    Data: 15 MB
    Test Time: 10.69 secs
    Your line speed is 11.73 Mbps (11730 kbps).
    Your download speed is 1.43 MB/s (1466 KB/s).
    Results for Whirlpool
    Test run on 16/12/2007 @ 07:52 PM
    Mirror: AAPT
    Data: 9 MB
    Test Time: 21.54 secs
    Your line speed is 3.51 Mbps (3509 kbps).
    Your download speed is 439 KB/s (0.43 MB/s).
    Test run on 16/12/2007 @ 07:53 PM
    Mirror: Adam Internet
    Data: 15 MB
    Test Time: 15.06 secs
    Your line speed is 8.32 Mbps (8321 kbps).
    Your download speed is 1.02 MB/s (1040 KB/s).
    sorry forgot to mention , I'm on a LAN with 3 Computers connected... 2x laptops and 1xPC
    Last edited by Disco_owner; 16th December 2007 at 08:41 PM. Reason: providing technical info
    We probably need to use the same test.
    I used: Oz Broadband Speed Test - Bandwidth Test
    I'm on Optusnet cable. These tests were run with two of us surfing the net via a router. The router has this PC hard connected, plus two laptops and two network printers currently connected.
    Test run on 16/12/2007 @ 07:16 PM
    Mirror: OptusNet
    Data: 3 MB
    Test Time: 42.91 secs
    Your line speed is 571 kbps (0.57 Mbps).
    Your download speed is 71 KB/s (0.07 MB/s).
    Upload Test
    Results
    You uploaded 104 KB bytes in 8.45 seconds.
    kbps: 100.88
    KB/s: 12.61
    Mbps: 0.1
    Warragul, Victoria
    1.5Mbps, at least thats what the little connection doover in my system tray is telling me.....
    Maleny, Queensland
    Speed has dropped a little noew - usually does after 6pm when everybody starts surfing...
    Mirror: Telstra Bigpond
    Data: 600 KB
    Test Time: 2.09 secs
    Your line speed is 2.34 Mbps (2337 kbps).
    Your download speed is 292 KB/s (0.29 MB/s).
    You can see my results are abysmal for a cable connection.
    Oct 2007
    well, in theory on cable you should be getting faster but it is not just dependent on your connection, it is dependent on the other end. IF your using torrents then things like seeders and lechers make all the difference.
    400 is a good speed but cable is made to run at over 1000kbs and adsl 2 is 2000kbs.
    Don't let the Telstra folks use the upload test cause they'll pay in download bandwidth for it!!! hahaha, Telstra is so dodgy!
    Brisbane, north of the river
    I'm on Optusnet cable as well.
    At the moment I am also downloading some Windows Updates to another machine in the same network.
    My results are as follows:
    Test Results from Oz Broadband Speed Test
    Test run on 16/12/2007 @ 08:13 PM
    Mirror: OptusNet
    Data: 3 MB
    Test Time: 2.77 secs
    Your line speed is 8.86 Mbps (8859 kbps).
    Your download speed is 1.08 MB/s (1107 KB/s).
    Maleny, Queensland
    Quote Originally Posted by Xavie View Post
    Not just Telstra - I thought Optus charged for data both ways too.
