Mmm, that's got me stumped. They sure look like, and are positioned like coil spring mounts. anything else out of the ordinary on the chassis??
I noticed these welded to my chassis, they look like coil spring mounts to me.
Would I be correct in thinking this?
There is not anything on top of the axles to attach to.
1994 Discovery TDi
2004 Discovery 2 TD5
2010 Discovery 4 TDV6
Surface rust.
I will have a look around, I did notice that the leaf springs are heavy duty 13 leafs back, 11 front is this usual?
I think 9 is normal except on the front of the ambulances which had 11. Dinty will be able to correct me though
I have a couple of photos of RAEME modifying vehicles in strange ways for kicks, maybe this was one such project?? I'd give underneath a once over to see if there is anything else?
1994 Discovery TDi
I have a few differnt mount holes for shock absorbers on the rear, tubed & welded, different heights & angles.
And my rear bar is different.
How many cross members should there be?
That could be the case Diana, but considering it's a SWB, and already has heavier leaves?? maybe the heavier leaves were added and the coils removed?
xmember looks right, but without the PTO hole, is it a plate over, or maybe a home made replacement xmember?
1994 Discovery TDi
From the pictures, as far as I can see, the coil would be in front of the axle, probably on a plate clamped between the axle and the spring. This would have been removed when the heavier duty springs were fitted, I'd assume.
Possibly they were only a trial and discarded as unsatisfactory, fitting extra spring leaves instead. The lower mount was removed as it was bolted on and the upper stayed since it was welded.
