Results 1 to 10 of 17
Thread: Prodigy Brake Controller
    Nov 2007
    Does anyone know which colour wire on the brake switch to cut into for the brake pedal sensing. Maybe a Photo?
    Melbourne, Australia
    Quote Originally Posted by muppo View Post
    Muppo,
    Its the Green with Purple tracer. Don't cut it just splice into it.
    You'll find the man where this info came from on here with pics:
    DISCO3.CO.UK - View topic - Electric Brake Controller Wiring
    Chris
    Nov 2007
    G'Day Chris,
    Thanks but I posted the same thread on Disco3.co.uk and was told that connecting to the brake switch wires is a no go. I have to wire it to the LHR compartment where the wiring is for the trailer loom is and use a diode to stop back feed.
    Western Australia
    Muppo, I had to rewire mine, I originally had it spliced into the cold side of the brake light switch but ran into some problems with my suspension and terrain control dropping out. The dealer convinced me that the pickup for my prodigy had to come from LHR cold side of the stop light and a diode to stop feedback.
    Now I don't understand electricity and the way it works and it didn't stop my suspension problems which turned out to be a loose earth connection, however everything works fine and it is now wired in as per the dealers recommendations.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    Quote Originally Posted by RichardK View Post
    Thanks Muppo and Richard for confirming that wiring to the brake switch is not recommended.
    I've done that and had some supension errors, terrain response errors and tranismission faults recently .
    I've asked Sniegy to better explain which wires I'm meant to connect in the fuse block becasue it isn't very well explained in the Disco3.co.uk post
    Regards,
    Chris
    Queensland
    I had to call into my dealers service center today so I asked what was the go.
    They do a few installations and the way they explained the install is like this and I hope it means more to you than it does to me as I have never had to do such an install.
    They pickup power at one of the two plugs at the rear of the D3 and pickup the Stop Light wire in the seven pin plug that goes to the trailer or caravan.
    There is no need for diodes and because it’s after the trailer wiring module, there is no effect on the D3’s electronics.
    No sure if that’s what your after but thats how my dealer does it.
    I rewired last night as per my Dealer's instructions using the recommended LRA method. This uses the trailer fuse block in the LHR compartment for all connections with a 3amp diode between the brake light wire and brake controller's blue wire.
    I'm sure you can wire these controllers up and take a brake light signal from different locations some with no risk and maybe some with higher risk.
    I'm happy to have fitted as per my Dealer's instructions. Thanks Sneigy.
    Chris
    Sydney, NSW (nr Epping)
    Quote Originally Posted by PCH View Post
    Chris
    This is one MORE job that I have ahead of me (after removing it from my D1).
    Can you please let me know which way round to fit the diode?
    AND I'll have to see if can DIG UP the installation instructions.
    Best Wishes,
    Western Australia
    I've got them here somewhere, I can PDF them on Monday if you like
    RichardK
    Hi Richard,
    That would be great!
    Thanks very much,
