Results 1 to 6 of 6
Thread: Front Driveshaft
    DiscoDave Guest
    Front Driveshaft
    Since I was underneath my 109 checking the gearbox and transfer case oil levels (I'm getting better at this maintenance stuff ) I thought I should grease the driveshaft uni joints and shafts. While doing this I discovered the front driveshaft has a fair amount of slop in the shaft - where the boot is covering the sliding section - which would explain the rather amusing out-of-balance-washing-machine type of noise that sometimes occurs when I pull up at the lights. The movement is maybe 20mm from side to side.
    How concerned should I be about this? Immediate driveshaft replacement or worry about it when it starts hitting the cross-member?
    S.W. Sydney
    If its under the boot the spline has worn in the slideing part of the shaft
    if its bad 20+ mm of movment is bad I would replace it the last thing you wont is a prop shaft comeing through the floor and belting you in the leg
    not nice,
    Tony
    since its a series unbolt it quick smart and dont put it back on till you have a replacement.....
    just remember no 4x4 without it...
    As above - if it really is that bad (20mm) I would avoid using it except at low speed. Either remove it or fit free wheeling hubs.
    Actually free play on the spline is not as bad as on the U-joints - the spline has to be very badly worn to let got, where the U-joints don't, as once they start to hammer the needle rollers quickly disintegrate, allowing more movement, and only a few hundred more turns will destroy either a cup or an arm and it lets go. But a loose spline that bad will cause sufficient vibration to cause all sorts of strife, from busted U-joints, to loose drive flange bolts to output/pinion shaft bearing failure.
    And the symptoms as you come to a stop suggest you may also have a dragging handbrake!
    DiscoDave Guest
    Thanks for the advice - I'll remove the front shaft and have a good look at it.
