Results 1 to 9 of 9
Thread: Heavy Power Steering
    Unhappy Heavy Power Steering
    Our 05 Def 110 seems to be getting heavier in the steering. I'm not sure if I've gotten used to other cars or it's actually not working so well.
    I do think it's getting quite heavy now to the point where you know you're working to turn the wheel, and I don't remember this being the case. I noted it on Fraser IS and in the local streets.
    I've checked the tyre pressures and the fluid res. I'm also conscious not to leave it on full lock for more than 40 secs (as per the manual).
    Can anyone tell me is this symptomatic of any known problem? The car is still under warranty so I'm sure LR will cover the repair but I was hoping I could go there with a heads up on what it might be.
     2005 Defender 110 
    May 2002
    Heathcote (in "The Shire")
    Check the universal at the end of the steering column - it may be siezed.
    Martyn
    Quote Originally Posted by Bushie View Post
    Martyn
    I know the one and it looks pretty shiny. I'll spray some CRC on it.
    Any other ideas?
    Nov 2006
    narellan, sydney
    Quote Originally Posted by Captain_Rightfoot View Post
    Any other ideas?
    Yeah, drive a 2a for a week, then get back into the 110. never complain about steering again
    Is it making any noise apart from when its on full lock?
    Quote Originally Posted by andrew e View Post
    Nope.. no noises other than all the usual ones
    It also feels a tad wooden... ie if you turn it it kind of feels as though you're pushing some resistance... like the assistance is running out.
    Eidsvold QLD
    Try your steering damper, mine dropped its guts and the symptoms were the same as you describe.
    Hmm, heavy and wooden.
    Aren't driving the Christmas presents around, are you?
    Sounds like a job for the Toy Mechanic.
    Simon
    Quote Originally Posted by crump View Post
    They did replace that a while back but that one could get up
    Nov 2006
    narellan, sydney
    remove it and drive around the block, see if there is any difference. Yes its safe before you ask.
