View Poll Results: How far could you go in modifying a Rover?
Voters
103. You may not vote on this poll
  • Not at all. If it's not from the factory, it's not going on!
    3 2.91%
  • If it's designed for a Rover, but not made by Rover, then it's still cool!
    30 29.13%
  • Dont care where it's from, but if it's good, then I'll use it!
    72 69.90%
Multiple Choice Poll.
Results 1 to 10 of 21
Thread: Good Rover! Bad Rover! Mongrel dog!
    99.87 MB
    Just a thought from another thread regarding Landies, their purity and owners perspectives.
    There are a lot of people on here that look to get different things out of their Rovers, some purists, some modifiers and some that look at them as a machine or tool to do a job.
    I know there are a lot of people that share the view it is important to keep it Rover - even when modifying.... then fit 4.11's from Ashcroft, lockers from ARB, axles from Maxidrive, Springs from LRA, shocks from Bilstein, bushes from Superpro, lower links from 3rds, radius arms from Qt, driveshafts from Tom Woods, snorkels from Safari etc etc etc and so it goes, but nothing Rover.
    But when is Rover not Rover. In my Discovery is 4,11's ARB diffs, Maxidrive half shafts. There isn't actually anything in it from LandRover and there are a significant number of people that have the same running gear..... and they do this happily, but quite categorically NOT consider running for example a stronger Toyota diff and JacMac half shafts inside their Rover axle housings because it is not LandRover.
    I'm just curious about thoughts behind modifying and what you would/wouldn't do in this respect.
    Slunnie
    I buy rovers cause out of the box they are the best at what they do... Whats that? 1st and second in 4x4 of the year?....
    I dont do 4x4ing just because I want to see how far I can go I 4x4 because I need to be able to. The stuff I do for fun is basically skills honing, route selection , road building and avoiding the stupidly hard stuff is more my speed.
    Im not against modding a rover tho, when a bit wears out (suspension, axles, diffs) If theres something better or more accurately something that makes the vehicle more capable in the fields I need it to be capable in at a reasonable price (not significantly more than genuine parts, cheaper and not requiring major re-engineering or other component replacement) Then I'll upgrade it as it wears out. But I aim to keep it so that if something breaks out whoop woop then I can still fit stock rover parts If I have to which is important in terms of repairability and reliability.
    If I was tempted to build an offroad weapon then Id be using anything I could lay my hands on.
    NSW far north coast
    # 3, I'm no purist.......unless I had an early Series I.
    Same goes for Jeep. If it's an MB it has to be as original as possible, but anything later is open slather as I'm concerned
    RonMcGr Guest
    I'd love a Disco with guts.
    However I would not stick a Jap or GMH engine in it.
    Jaguar V8, yes, cos they do that anyway :-)
    Not only that, some jag V8 imports are cheap as well.
    Melrose SA
    If it continually breaks or wears out I am not opposed to using something that doesn't dont even care if the bits are Japanese.
    Kiwiland
    I've got a jap engine and gearbox, guess which box I ticked?
    I view a landrover product as an almost blank canvas.
    99.87 MB
    Quote Originally Posted by Dougal View Post
    That's a keeper!
    I'd never heard that one, but I think LandRover until recent times did also.
    Slunnie
    That's what I love about Series/Defenders - you can fit anything to them and it looks right.
    Want a shovel? Throw it on. Where it sits, bolt it there. Can't do that with my P38A!
    mcrover Guest
    My rule's for picking mods is:-
    1. Reason/Nessesity, I dont just bolt things on so I look like I go Rock crawling etc.
    2. Legality, I dont want to end up in a situation where I cant travel on public roads in my 4b, If I had a comp truck I wouldnt be concerned about this other than it keeping within class rules.
    3. Availability, I dont want to be fitting something that I wont be able to replace or have repaired if nessesary.
    4. Like Dave said, Compatability is also important.
    I do think that anyone that owns a 4wd should be completely aware of the legaity side of their Mods and not rely on the opinions and ideas on here and actually get in contact with your local road traffic authority to make sure what you are doing is legal.
    Also do not rely on the so called knolage of the sales person saying something is legal etc as they are in the end wanting to sell a product to you and after that it isnt their problem.
    These are my opinions only and not meant as or to be used as guide lines.
    Gilderoy, Victoria
    A Land Rover is about the only vehicle you buy and then finish building it!
    I try to stick to Rover specific, as in I'd pick Maxi Drive over ARB, even though the ARB is cheaper and easier to fit.
    I'd rather spend some money and experiment with a rover V8 than just get instant power from a chev conversion.
    I'm somewhere between purist and the second option.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
