Sounds good
This my brothers LSE
2" body lift, 2" coil lift, ARB bumper, T MAX winch, Beadlockers, 35" Maxxis crawlers
Well, I had fun today
Replaced the front springs and shocks, ordered the 9000lb OX electric winch, fitted the ARB winch bar, serviced it, repaired minor exhaust manifold leak, cleaned the rest of the breather system and throttle body/ set base idle, correctly fitted/adjusted the kickdown cable,(Tony, I would be having a talk to your Auto trans people...) fitted A frame ball joint and steering column unis, wheel aligned, washed it,lubed everything in sight....
beautiful!
The windows will be tinted, 235/85/16 Cooper ST/s and the roof lining replaced in a fortnight, rego inspection and A/C regas by friday.
SWMBO is mightily impressed ATM.....
It's difficult being this good, but someone has to do it!
It sure is nice to have 2 RR's in the stable now!!
JC
Sounds good
95 300 Tdi Defender 90
99 300 Tdi Defender 110
92 Discovery 200tdi
50 Series 1 80
50 Series 1 80
www.reads4x4.com
Hi Ali,
Pic doesn't work, but I've seen it posted before and it is a weapon. 35"S and beadlocks aren't in my ballpark I'm afraid, but looks the business on that one!!
This is also the shopping car and school run vehicle, so aswell as getting filhty on w'ends etc it has to be a smooth and quiet, like an LSE should be..
Can't wait to get MY RR back from the other half and give her this one!!
JC
Had to scare a young punk in a VL Commy the other day, idling along with the Doof Doof music on, trying to look
, so as the IsuzuRR is big and high up and noisy I 'pushed ' him all the way through the roundabout and when he exited didn't he GO!
That'll teach these young'ens to drive!
( By 'Push' I mean drive REAL close...
JC
We need Land Rovers on the road to educate young people![]()
Well done![]()
It certainly looks the goods JC, a very nice ride indeed! Thanks for getting the g'box and winch down for me mate, ill buy you another beer (xxxx cheap stuff :P)
Bugger justin I'm sorry mate I never relised that much needed doing,I thought new shocks and a service would have seen it ok, As or the auto box I will be going and haveing word with him but at a guess its been 3 years sence its been there so it'll just be a bugger steve you did'nt do a very good job...did the old girl shine up Ok ?
T
Don't worry T, Very happy with the condition actually. I just went and did all that stuff NOW because I can
As for the Auto, the kickdown cable isn't a RR one, as these 4HP22's are available for many different vehicles, I suspect he had an 'equivalent' one on the shelf at the time...It was a problem only that the clevis pin arrangement at the end of the cable is not correct, and actually prevented full throttle, and the kickdown adjustment was WAAAYYY out due to the cable end fouling the throttle linkages. All fixed now though( I hate corner cutting, whats wrong with using the correct cable!!!)
Anyway, pics will be up soon hopefully!
(Do you want the Elvis CD back I found in the stacker???)
JC
