now thats a well posed can of worms....
just for openers with all the other stuff your planning to do (Assuming your disco has a CDL )Id have thought that just a rear on demand locker would have pushed you through most of what you might come across and then you could fit another to the front later.... But theres a couple of little things you might be a tad off of the mark on...
changing the dffs (unless you also change ratios) doesnt really put any more strain on any other component than a normal rover diff does and unless youve got a bung diff wont add anymore noise, that usually comes from your choice of rubber.
the castor correction isnt a problem for changing the diff (unless Im off the mark on what your calling a true track diff a true track is just a diff that is desinged as an lsd/lock diff for a front axle) its from lifting it, as you lift it the front axle pivots down on its locating arms and this in turn changes the castor (and kingpin inclination angles+ toe in on turn adustments) which is what you need to correct. all of which now requires inspections to pass for roadworthy and its getting harder to get that stuff past.
hope thats helpful in some way.
