Results 1 to 10 of 14
Thread: ZF to 200TDI
    VIC
    ZF to 200TDI
    Right, it seems my plans have been unravelled yet again and I best clarify this before I make an a*se of myself at a Land Rover specialist.
    If one wants to fit a ZF automatic to a 200Tdi Discovery (and don't tell me that they never came like this because they did, we just never got them here), which bellhousing is needed? Is it a specific 200Tdi auto disco bellhousing or is the 300Tdi auto disco one the same?
    Moving on to the drive plate. The 200Tdi auto one is listed as FTC4049. Is this going to be available? I thought it was the same as the 300Tdi one, it rather ambiguous... can someone with a parts manual clarify this please?
    Moving onto the torque converter, STC1580, good this is for both 200 and 300, and the box itself FTC2756 as well.
    FFS someone please answer my prayers and steal this vehicle.
    Jun 2007
    Quote Originally Posted by joel_nicholson View Post
    the box, converter and the crank parts are all the same as the 300, only difference is the engine backplate, this needs to be the 200 one, part number ERR 4612,
    May 2002
    Sydney, Australia
    Quote Originally Posted by ashtrans View Post
    Cheers Dave
    can you pls answer the perennial ZF question - is the ZF on the D1 V8 the same as the one used on the D1 Tdi?
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Free Again Thanks Dan
    Quote Originally Posted by LRHybrid100 View Post
    Cheers Dave
    Ive heard not as the change pattern is different on the diesel compared to a petrol
    Adelaide - Torrens Park
    Cheers Dave
    Yes and no. Essentially the same box, but with detail differences. In particular the torque convertor won't be interchangeable.
    VIC
    Thanks. So if worse comes to worse I have the part number to buy the correct backplate.
    St Helena,Melbourne
    4.28 MB
    Better start looking for a low k disco wreck with tdi and auto then ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    VIC
    Or maybe a new low k diesel auto 4wd?
    I'd never find a Disco 200 Auto here, and wouldn't it be pointless to put a 300Tdi and auto into a LA chassis Disco? Esp. considering that my diesel engine is in excellent working order and has had a lot replaced/rebuilt on it.
    I honestly have no idea where to go from here, I'd like to get my disco back on the road but maybe its time to get out of the LR game...
    St Helena,Melbourne
    4.28 MB
    Lets not get carried away, just find a good LT77 if 1 exists or replace with an R380, cheaper to keep it manual than shell out for a 2nd hand auto you dont know the condition of and waste even more money.
    1974 VW Kombi bus
    darwin
    why do you want to go to an auto
