Thread: after market injectors wanted ???
    Nov 2007
    Townsville Nth Qld
    Hi the saga continues on my 3.5 had injectors serviced but they stated they were poor just in specs. with one with rust in the bore. Anyway after sitting for a few days the beast takes several goes to start. Fires on one and coughs and farts ecte. When it starts strong smell of fuel. Now I have set evreything as pers specs maff ect. Any hints all parts vac and fuel ok can only guess injector leak by over the time leading to flooding of pots. Has anyone the part number and supplier for after market injectors..... As i can't afford 200 a pop at this time.
    Baz
    Williams West Aust
    Our Rangie has Commodore 5lt injectors as its a mildly worked 4.6.Im guessing the Falcoon XE/XF and EA/EB would be similar as they are all bosch.Find a wreck and grab some to try,the EA/B should be real easy to find cheap.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Avoca Beach
    RRC 3.5s have injectors with hoses on top, not O rings that fit in sockets like modern Commodores etc or even 3.9. Unless it is a Disco 3.5.
    AFAIK they are unique.
    Maybe try here.
    Performance Fuel Injectors - Bosch Injectors, Siemens, Denso
    I have bought replacement 3.9 injectors from them and good service.
    Regards Philip A
    Nov 2007
    Townsville Nth Qld
    More info
    Beast is a discovery s1 with o ring type injectors
    Avoca Beach
    Well check if your injectors have a green band.
    If they do they are the same as 3.9, and the Fiveo motorsport ones should be OK.
    Regards Philip A
