Thread: Bedding in new disc pads?
    May 2003
    On The Road
    is there a correct way?
    Gilderoy, Victoria
    Use the handbrake for the first 50k's pete.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    NSW far north coast
    depends a lot on the pad material.
    Some have bedding in info in the box (Ferodo)
    Most modern compounds these days just drive lightly for the first 200 or so km to snub the material into the disc and drive normally.
    Have to say, after installing my first set of Ferodo 4WD pads a few years back was seriously underwhelmed with the braking performance after following their recommended procedure, so the old DS11 pad trick of a couple of huge stops generating green fade then 20 min of driving to cool everything off sans brakes and the buggers were transformed.
    May 2003
    On The Road
    I've always done the huge stops thing,,,
    (especially on parents/sisters cars)
    but its been, what? 5-6 years since my last pad change
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    most i have come across require you cure the pad by heating them up.
    about to get some for the back end of the fender so will let you know :P
    whats a decent brand these days?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    NSW far north coast
    all you are doing when fading them is burning out the resin binders used during manufacture.
    Most these days are already done, to greater and lesser degrees before the pads leave the factory. Most race pads are pre-bedded (or burnished in US speak) these days.
    Capalaba.Q.L.D.
    4 years of towing etc and disco must be getting close,so,as Dave asks,whats a good brand/type to use??
    ps.disco 2 00 mod.
