Thread: Air Suspension Compressor Failure
    Heathcote Junction
    Has anyone heard of air suspension compressors failing when fitted with front or rear bars?
    Have heard rumours that compressors may be failing with the extra weight & are not being replaced under warranty.
    Chuck
    Feb 2005
    so long at no stage does the car exceed the GVM? i think thats what it is there should not be a problem
    Nedlands, WA
    None whatsoever. An urban myth put out by the jealous.
    Compressor failures in 2004/2005MY D3's were due to valve issues and had nothing to do with weight.
    I've got bars at the front and rear, aux tank, dual batteries etc and the compressor doesn't miss a beat.
    Melbourne, Australia
    I concur with Jamo.
    There are many D3' getting around with Bull Bars and winches on the front. Haven't heard of compressor failures due to weight.
    Chris
    Toowoomba
    I have a Kaymar rear bar and carrier. I had a one of suspension failure but that was almost 2 yrs ago, even then it corrected itself,
    Stevo
