Results 1 to 10 of 17
Thread: Throwing clutches
    Throwing clutches
    G'Day guys! I bought a 92 Disco about three and a half years ago and thought it was the best thing on earth. About a year ago my clutch went. The clutch assembly, master and slave cylinder were all replaced. My clutch is now slipping again. Does anyone know if the 92 disco are prone to throwing clutches?
    not usually, but if your still on your original clutch you might find that this time its actually slipping and not a hyds problem
    The original clutch was also replaced. The mechanic told me that this clutch 'would outlive the life of the car'.
    May 2003
    On The Road
    yea,, what Daves saying is--
    what did they actually replace last year?
    clutch AND pressure plate?
    and master and slave cylinders?
    just trying to sort it out
    Clutch, pressure plate, throw-out bearing and the flywheel was machined.
    Williams West Aust
    Any oil driping from the bellhousing???
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    There is only enough oil to coat the thread when I remove the bellhousing drain plug every 6500km's.
    Urmmm have a really good look at your bellhousing and see if you can see any signs of spanner markings on the bolts that hold it together...
    I've got some questions...
    IS this going to be a DIY?
    are you any good with the spanners?
    Doing this leaves you with NO abiltiy to declutch so you want to be good at manipulating the other vehicle controls to compensate for the purpose of the test.
    Find a slight downhill with a good run off and turning area.
    grab a brake hose clamp and lock off the clutch slave at the flex hose, then unbolt the clutch slave, once its outwrap an elastic band around it to stop it coming apart and secure it somewhere.
    in 1 high with the vehicle facing down hill start on the starter and bring it up to a bit of speed, keep your foot on the noisey pedal and using your left foot mash the brakes and try to stall out the engine. If it slips get off the brakes and the noise, then snap the main shifter into neutral, stop and replace the slave cylinder. Your up for at least a new friction plate at this point.
    If it doesnt slip without the slave cylinder in repeat the test with the slave cylinder in after pressing the clutch pedal a few times. If its slips your up for a new (or rebuilt/rebuild it yourself) slave cylinder as its pitted and is jagging the piston and preventing it from returning all the way.
    Heres hoping its just a fouled slave cylinder and your previous mechanic did the righty by you.
    Karratha WA
    If the external clutch conponents are OK then it may be the following cause that is now giving you grief.
    I have seen in some manufacturers fly wheel face designs when a flywheel has been machined where the clutch plate faces, the pressure plate face on the pressue plate unit where it bolts up needs to be machined the same amount. Otherwise this leaves the machined off surface on the fly wheel adding a wider difference to when the pressure plate contacts.
    This is most often the case when the shop buys in the new clutch conponents and sends off the fly wheel to be machined. As the machine shop ususally does not have the new pressure plate unit as it is on order back at the shop or sitting on the bench.
    This is OK for about 18 months to 2 years depending on how much has been machined off and your driving habits before the cluch friction plate wears down enough to start slipping again.
    In some design cases the pressure plate mounting face should definitely have been machined down the same amount as came off the fly wheel for this not to happen. I suspect in your case this may possibly be the situation.
    I must state however at this point in time it is only theory as I have never seen a Landrover clutch apart and do not know the finer points of it's design.
    Fortuntely for me over the years age has bought me some wizdom coupled now with the lack of 300 hp+ upfront. I also switched to automatics to handle the hp.
    BradM
    Thankyou muchly for you help
