The turbo housing in the 300Tdi is integral with the exhaust manifold for starters. And since the Tdi produces max boost from around 2300rpm, you wont achieve any benefits above this RPM (once max boost pressure is reached, excess pressure is dumped out the wastegate). I think the variable vane turbo from the HS2.8Tdi engine can be purchased with manifold (at least there was a guy selling these around 6months ago) and I assume that would generate max boost lower in the rev range (spin up faster) with the associated improvement.
