Results 1 to 8 of 8
Thread: harmonic balancer
    Sussex Inlet. N.S.W.
    harmonic balancer
    Anyone had problems with harmonic balancers wearing and causing vibrations? Jim
    yep, but usually before this becomes an issue it eats the belt.
    McDisco Guest
    Yep! had that happen 400km from home...expensive fix too. Get it looked at now...
    Angus
    Mar 2007
    Perth WA
    Rover V8 balancers are notorious for shifting timing makes. Mind you most rover v8 harmonic balancers would be at least 12 to 13 years old??
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Lucus View Post
    Yep, chewed thru 2 till i found the cause.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2007
    Perth WA
    What did you find the cause to be?
    Quote Originally Posted by jx2mad View Post
    V8?
    200Tdi
    300Tdi?
    St Helena,Melbourne
    4.28 MB
    Bolt thread in the crank was gummed up and it wouldnt allow the balancer to be tightened hard up against the crank snout, i used a shorter bolt and it was good after that.
    1974 VW Kombi bus
