Pete, before buying another air flow meter remove the wiring plug and clean both lots of plugs and receptors with electrical contact cleaner, if the the male pins are split, use a small flat bladed screwdriver and gently open them up a mickey, connect and diconnect a few times and see if that solves the problem, sometimes a loose fitting or dirty plug can cause this problem.
Also (if fitted) check the Idle Air Control valve on the back of the plenum chamber is bolted up tight, remove it and clean oil and carbon deposits off plunger valve and it's seat, do the same to the electrical plug as you did to the air flow meter.
Come back with the results here and let us know if it helped or not, Regards Frank.
