Results 1 to 9 of 9
Thread: Mrs Hiline: Help Please
    Ferntree Gully VIC
    Can anyone help me with this problem??
    MY 97 HSE's new trick is to stall. I can go to the shops no problem then when I come out every time I start it it stalls. I can manage to get go with a lot of rev's but each time i have to turn or slow down it stops again. Now this doesn't happen every day just now and then.
    What could be causing this any help would be appreciated.
    Mr Hiline is of no help what so ever
    Fiona
    130's rule
    Quote Originally Posted by hiline View Post
    Fiona
    blocked/failed Idle bypass ports/steppermotor.
    SYDNEY -in the shire.....
    my reply too.......stepper motor......
    NSW far north coast
    <snip>
    Fiona
    Is that just now, or mostly, Fiona ?
    if you want hiline to be of more help.......
    just his car.......im sure yours would get fixed before you got as far as the driveway......
    This has been done not so long ago ???
    I seem to recall that Mr Hiline questioned this ages ago....
    oh, hang on...now I get it
    Jeez Hiline, you're slack. Pull your finger out
    Mr Hiline has done well
    December 2005...
    p38 just stops
    Oct 2007
    Quote Originally Posted by Feral View Post
    December 2005...
    p38 just stops
    Xavier
    Invermay Tasmania
    My disco had the same problem (mine was the stepper motor)
    Adam
