Howdy Steve. I would go with getting a kit as it is only $5.50 for one . to get the cup out of the spring , compress it a little and remove the small rod out of the slotted hole in the cup . The cup should then just slide out . to get the seal off the piston just get a small screw driver and pull the seal back over the lip . It is a tight little sucker too
. but it shouldn't take you more than a few seconds to pull it all apart
A few taps on the bench and the piston popped out
The Piston
