Results 1 to 10 of 29
Thread: Series 2 or 3 with Softtop owners pls...
    Samford, Qld
    Hi guys,
    my restoration is (slowly) coming to an end (yeah, right...)...
    Anyway, I want to convert my Series 3 SWB to a soft top. Can anybody send me / post a pictures of what the seat belts are fitted to?
    They used to be bolted to a mounting point on the hard top (the upper bit that is)...but where does it go on a soft top?
    Thanks,
    Thomas
    thomas_kuenzel@yahoo.com
    Jun 2003
    Launceston, Tasmania
    I've only got lap sash belts in my soft top series 3.
    I have seen some attached to the top of the bulkhead though.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Phoenix View Post
    That would be lap belts, otherwise known as "2 point" belts.
    My S2B trayback, deluxe cab trim, has the 3rd (shoulder) point on the gal capping behind the seat.
    On the same issue, where is the 3rd point usually fixed on a ute cab?
    Diana
    WA
    I've gone from a soft-top to a ute cab. On the soft-top, I had static 3-point belts with the shoulder part fitted as mentioned above. The galvy capping has a welded-in nut for seatbelts.
    With the cab-roof, there are brackets you can get to fit the shoulder strap up next to your head. I've seen hard-top type brackets used but there are specific brackets you're supposed to use for the cab.
    Foot of the Otways
    I'll be mounting my seatbelts to the bulkhead behind the seat. But could be going with just the lap belts yet
    1.20 MB
    Quote Originally Posted by Davo View Post
    .... With the cab-roof, there are brackets you can get to fit the shoulder strap up next to your head. I've seen hard-top type brackets used but there are specific brackets you're supposed to use for the cab.
    Thanks Davo
    So now I need to find a set of ute cab seat belt brackets - maybe even a the whole cab which hasn't had an elephant sit on it?
    Diana
    1.20 MB
    Quote Originally Posted by wannalandy View Post
    Andy
    I would be avoiding 2 point belts at all costs, there are some very significant dangers with their use in a crash.
    Diana
    DiscoDave Guest
    Could you post a photo please? My SIII came with 2-point belts in pretty bad condition and it would probably be a good thing to replace them with something safer.
    Foot of the Otways
    Andy
    Diana
    Hi Diana . No doubt that the sash belt is a lot better than the lap belt . But isn't any seat belt better than none at all . I don't have to get them in my 2a but i'm putting them in anyways .
    I agree with you. Three point belts are a lot better than two point - but the really big difference is between any seat belt and none. Diana is comparing two types of seat belt, not looking at the alternative that may be no seat belt at all.
    Not directly related, but the fixed (non inertia reel) three point belt is in some respects safer than the inertia reel type, if properly adjusted, so don't worry too much if you can't fit these, although reaching the handbrake or starter button of the earlier Series Landrovers while wearing one is an acquired skill.
