Results 1 to 10 of 17
Thread: Hookes uni joint
    Mar 2007
    perth western australia
    Hookes uni joint
    Hey guys
    Heard a noise under the Disco had a look and the front uni in the Hookes uni joint is beyond being usefull I have rang around and was told I need to replace the whole thing
    Surely you can get the unis knock the old ones out and replace them with new ones ?
    lokka Guest
    Quote Originally Posted by Ken View Post
    Hey guys
    I take it your talkin bout the double cardan on the transfer end of the front shaft of your d2 ??
    If so its not as easy as it sounds take it to a driveline specialist and they will sort it proper my brother had his done a few times in the time he had his d2
    Mar 2007
    Quote Originally Posted by lokka View Post
    Yep thats the one
    After I calmed down I thought and remembered Veales in Canningvale rang em and he said roughly 200.00 to replace all three uni joints and balance the shaft not bad I thought compared to what a whole new shaft is worth
    Williams West Aust
    Hey Kenneth
    You didnt mention that when we were chatting this morn.
    Go to Albany there are at least 2 mechanics that have rebuilt them this year
    My unis were around $43 for the pair.The mechanic charged me $198 for around 5 hours labour,mainly because he had never done one and I actually worked the "EYE" joint out between the 2 unis and helped him do the job.
    RAVE CD / Dealers are no good,buy a new shaft.
    Make sure you search both mine and Davros' posts before you let anybody touch yours.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Mar 2007
    Gday Andrew
    Had heard the noise for the first time yesterday and then again today on the way home then when at home had a squiz and low and behold one knackered uni
    Have rung Veales in Canningvale and they specialise in driveshafts theyve roughly quoted $200.00 for the job so Id say thats sounding about what you paid to have yours done and I should have it back the same day or early the next
    Williams West Aust
    Hi Ken
    Make sure they put greasable unis in.You need the nipple between the spiders not on the flat face,better still on the end of a lobe if possible(I couldnt get them).
    Also get a nipple put on the sliding joint where the grub screw is,it shouldnt hit the xmember if a small one is used.
    MAKE DOUBLY SURE THEY HAVE DONE A LANDY HOOKES JOINT!!!!!!!
    The LOWLUX ones dont have the eye between the 2 unis,the guy who did mine hadnt seen anything like it and was quite a MATURE spanner man!!!!
    Andrew
    playing devils advocate......
    its because of the "center alignment bits" that I advocate that you dont rebuild the rover DC joint you replace it. If those bits get a bit of a hammering via shot UJ's they can look ok but there exists the risk that they are more likely to let go.
    that things not exactly light and its spinning at a fair rate and its right nextdoor to your gearbox and left foot.... you can guess the rest.
    If all the internal workings are replaced with the new UJ's this is obviously a moot point.
    NSW SW Slopes
    When I did mine the 1st time (as preventative maintenance!) I wrecked part of the centre bearing internals so replaced the rollers with a bronze bush. That lasted 10,000kms but eventually the bronze couldn't take the wear and the shaft got a little case of the rumblings but that's all. Admittedly there were no needle rollers to fall out to leave a big gap but the centre ball doesn't seem to pose any problem. If the joint comes totally apart then most likely the centering ball rollers are gone and there are damaged yokes too. For only chopped-out unis I'm most happy to just replace the unis, but perhaps others aren't.
    Mar 2007
    when you say internal workings do you mean the centre ball as well ?
    Williams West Aust
    The guy who did mine wanted me to take it to a retired mate to make a bronze bush up to replace the centre ball.I resisted that idea.
    Mine failed the day before the trip home,well only made chirping noises,only in certail conditions.
    It started chirping like a sliping belt once it got hot towing all the gear home from the holiday.
    It was only one of the unis that was on its way out and only because it was dry,the second uni and the eye had plenty of grease and were fine.
    The eye does very little as you will see when you pull one out ant rotate it off the vehicle.
    No need to replace the eye unless there has been a big failure,it doesnt really do anything as the 2 unis take the strain.
    Andrew
